Anyone have label placement tips? Options
Lickintoad
#1 Posted : 14 August 2015 00:28:33
Hi, all. I recently got my third package, so I went ahead and tried out the cockpit to see how it looked. Everything looked great until I turned on the light.
Now I can see that the label isn't properly lined up, and that is causing the light to pop through in the wrong places. I lined the thing up with the door, and one of the light bars looks okay. The other side, and the other light-up parts, however, seem off.
So, does anyone have any tips on getting this thing lined up hole-wise? The door and cockpit floor holes are lined up, but the light's just not shining through the right parts of the label. I'll see if I can get some pictures. Not sure how well they'll turn out on account of the bright light.
Lickintoad
#2 Posted : 14 August 2015 00:44:24
Here are some shots I took with my phone. They're not great, but they should give you an idea of what I'm talking about.
Cockpit lights off
Cockpit lights on
Right now, I'm looking at cutting a strip of index card the height of the light bars and taping it to the back of the plastic piece and then resetting the label based on that guide. Then, I can use my knife to cut the label to the new hole placement.
Viper DeCobray
#3 Posted : 24 August 2015 06:24:38
Rank: Beginner Level 3
I used a little bit of black paint on the back of the sticker to clean up some light bleed on mine.
This page was generated in 0.600 seconds.
