15 Pages «<910111213>»
steve's build Options
Steve279021
#201 Posted : 16 August 2015 13:00:11
Yes. I found that. When I got the monocoque out this morning one of the tapes had come undone so I stuck it back down so just waiting to see if it holds. If it comes of again I might redo it with a fresh one. Do you know if there is more tape then we need. I know there's plenty left but don't know if we need any for the rest of the build.
Dodge charger build complete
Steve279021
#202 Posted : 16 August 2015 13:06:49
Front brake ducts and left radiator housing fitted.
#203 Posted : 16 August 2015 18:14:37
Not sure if the tapes will be needed later on in the build but I suspect that there will be a couple of tapes spare.
Steve279021
#204 Posted : 16 August 2015 21:10:26
Yep, that one has come off again. Looks like I'll have to redo it. Anyway stage 56 finished now. Right side radiator housing and throttle bracket fitted.
Steve279021
#205 Posted : 19 August 2015 18:47:56
That's stage 57 and pack 16 finished. Injectors and fuel rails. Waiting for pack 17 now.
Steve279021
#206 Posted : 20 August 2015 20:56:31
Marlboro decals added to the chassis.
#207 Posted : 20 August 2015 23:27:01
Looking good Steve ThumpUp
Steve279021
#208 Posted : 20 August 2015 23:47:40
Cheers Dave. The end is approaching. I'm thinking I will be a bit lost when this has finished as I should be finishing the mp4/23 about the same time so will have nothing to do after that. Although I have been eyeing up the rb7 especially as rc is more 'my thing'!
#209 Posted : 21 August 2015 11:02:14
Some excellent work going on here Steve, so neat and tidy, you should be very proud - well done!! Love Cool ThumpUp
Steve279021
#210 Posted : 21 August 2015 11:12:51
Cheers KevLove
dandare
#211 Posted : 30 August 2015 10:03:36
great stuff Steve
you must store her in a vacuum, cant see a speck of dust anywhere
super clean and tidy
Dan
Steve279021
#212 Posted : 30 August 2015 11:16:53
Cheers Dan. This is how I store it(with a lid obviously!)
Steve279021
#213 Posted : 09 September 2015 21:17:17
Pack 17. Turbos!
Steve279021
#214 Posted : 12 September 2015 22:29:01
Stage 58 done. Fuel pipes and left turbo charger started on.
Steve279021
#215 Posted : 14 September 2015 21:30:30
Stage 59. Right turbo started on, fuel pump and header tank hose.
#216 Posted : 14 September 2015 21:54:37
BigGrin Looking good SteveCool
Steve279021
#217 Posted : 19 September 2015 22:04:50
Cheers andy. That's stage 60 and pack 17 finished now.
Wastegates
Oil/water heat exchanger fitted
Header tank
Engine and plenum sensors
Waiting for pack 18 now.
Steve279021
#218 Posted : 16 October 2015 15:31:50
Pack 18 here now, finally!
Steve279021
#219 Posted : 16 October 2015 22:04:33
Stage 61 started on.
Nose box fitted to monocoque.
Engine fitted with header tank and plenum.
Intercooler to plenum pipes.
Steve279021
#220 Posted : 16 October 2015 23:51:56
Stage 61 completed. Engine fitted to the monocoque.
This page was generated in 0.177 seconds.
