Crustys Build Diary Options
crustybaps
#1 Posted : 21 August 2015 02:24:45
I've been working on and off my model for the past 5 years but without help and guidance and not really knowing what I had let myself in for I found that I have made a few mistakes and progress was slow. Hopefully I will get some good tips here and look forward to hearing your advice and thoughts. So without further ado here is my model so far starting about issue 50
#2 Posted : 21 August 2015 07:21:01
Some nice looking progress ThumpUp
Ive posted in your other post, but just recap, ifnyou resize yiur pictures to 640 x 480 they will appear as actual pictures on your post rather than downloads BigGrin
#3 Posted : 21 August 2015 08:54:34
Welcome to ModelSpace and congrat's on your first medal Cool
z8000783
#4 Posted : 21 August 2015 12:43:07
Groups: Unapproved
Looks pretty good so far.
crustybaps
#5 Posted : 21 August 2015 21:01:51
Thanks all for looking at the pics. So far positive comments. The planking was a bit of a mess but I am going to continue on in spite of this and work on the premise that it didn't happen. For now I will be planking the decks and stuff and concentrating on getting that right.
#6 Posted : 22 August 2015 09:40:02
Welcome to the forum, hope you enjoy your time with us.... Great work on the build to date, look forward to seeing more of your work.....Cool Cool
crustybaps
#7 Posted : 26 August 2015 06:32:19
Ive decided to lo-res my camera settings and see what happens. Done some work on the cannons and unfortunately had a few mishaps but from what I understand of the build instructions most of this will not be visible, probably just as well in my case. I've decided to leave out the part where it says the main rope is optional and also very fidgety. I have all the tackle in place and all that remains now to do is insert the metal pins into the predrilled holes.
I've posted a pic of some damage to the front which broke off - I have managed to repair by placing a piece of balsa over the crack which I hope to sand off later but will keep in place for strength until i get ready to work on that part.
crustybaps attached the following image(s):
#8 Posted : 27 August 2015 00:46:14
Hi, have to admit the fitting of the cannons and all the tackle is a real fiddly and time consuming, at least until you find a technique that suits you then it's not so bad....Cool Cool .. Shame about the mishap but it is repairable. Should you need assistance to carry out the repair then give us a shout when you get round to that part....Cool Cool ..
crustybaps
#9 Posted : 28 August 2015 07:23:45
Thanks Alan, I'll post an ariel view of the damage as it looks a bit off to one side when seen from above- if you look at the top pic you will see a line where it was sheared off completely and i've used epoxy and some balsa wood sheet to strengthen things up a bit. Well fixing and repairing this sort of thing is all part of the fun I guess coming up with solutions.
This page was generated in 0.767 seconds.
