How to make half furled sails Options
nightwisher
#1 Posted : 31 August 2015 17:07:08
Thought I would share the method I used to create half furled sails. I'm not saying this is historically correct but is just a look that I came up with that I like. Step 1 attach lines to the sails at red and blue arrows then tie these to the yards at the corresponding dots pulling the lines tight. Step 2 Take the bottom corners of the sail ( green arrows )and fold them down and under. Step 3 turn the whole thing over and put a temporary stitch joining bottom corners to back of sail just below the block for the sheet line (green dot) this can be replaced with the sheet line later.
Turning over again should now look like pics 4 and 5. At this stage the sail still look a bit stiff and unnatural so now we need the magic ingredient plain old H2O. Dunk it in the water for a few seconds and give it a squeeze then you can play around with tweezers putting in some creases and wrinkles to give the sail a sense of weight,now with the ends of the yards resting on something so the sail is left hanging let it dry naturally. Should end up with something like pic 6 and that's it, pretty easy really and the best thing is there is no cutting of the sail material so if you don't like it you can just start again no harm done.
nightwisher attached the following image(s):
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#2 Posted : 31 August 2015 17:27:59
BigGrin Very nicely done on those sails Nightwisher lovely job Cool
#3 Posted : 31 August 2015 17:41:34
Many Thanks.
Very useful and I have several places I can use this in the future.
Cool Cool Cool Cool
#4 Posted : 31 August 2015 19:45:37
Brilliant, alwasy nice to see a new tip and results look great
#5 Posted : 31 August 2015 20:31:10
BigGrin Very nice and works well, great tipCool
#6 Posted : 01 September 2015 00:03:10
Great tutorial and one that will come in very useful in the future... Very well done and thanks for sharing....Cool Cool
#7 Posted : 01 September 2015 00:07:49
#8 Posted : 01 September 2015 08:50:10
A nice contribution to the know-how topic and congrat's on receiving the turqoise medal Cool
nightwisher
#9 Posted : 01 September 2015 14:03:04
Thanks guys and thank you for the medal Mr T.
This page was generated in 0.212 seconds.
