 Rank: Pro  Groups: Registered
Joined: 27/06/2015 Posts: 104 Points: 305 Location: nottingham
Hi, Onto Pack 10, the parts and build chink attached the following image(s):
Hi, Onto pack 11 and 12, Halfway point. chink attached the following image(s):
 Looking good, that engine will already weigh quite a bit Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi, Al your not wrong, gives a new meaning to the phase heavy metal Have done Pack 13, apologies for poor pictures of complete assembly. Not to hot on flash photography Even heavier now. Ian chink attached the following image(s):
 Hi, all Pack 14 done. Parts received and assembled. Fitting of kickstart a right fiddly job, took 3 goes to get it together. Also received a email regarding tank, Thank you for your email. A replacement has been logged for pack number 01. Please allow 14 days for delivery. Kindly returned return the damaged parcel to the address below. Looks like I'll get stages 1 to 4 and have to send 2 to 4 back with the damaged tank Ian chink attached the following image(s):
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Al, Thanks for looking Pack 15 parts and assembly. Left frame half just dry fitted as it is removed in next stages. chink attached the following image(s):
Very nice Ian
Great work Ian, she's looking good..... Regards Alan
Lovely progress Ian, looks great Steve
Hi, Dave, Alan & Steve. Thanks for looking, things are really coming together now. The next stages were done in a different order to the instructions, mainly to save having to take the frames apart again. That's it up to Pack 19 for the bike. Now got to go back to previous packs to do the display base. Ian chink attached the following image(s):
Hi all, The next steps for the display base. This completes the stages up to and including pack 19.  It's Big!!! chink attached the following image(s):
 All going together now, the base certainly gives a good idea on the size of everything. Nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
It is a fantastic looking kit!
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
WOW Ian she's really coming along & looks fantastic Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Very nice, it's great to see a partwork come together so quickly after being so used to waiting between deliveries - looks amazing Steve
 Hi Al/Nemesis/Dan & Steve, Thanks for looking in, This is a great kit and fun to build. Pack 20 up next. chink attached the following image(s):
 Getting towards the end now and be careful with those wires Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Al, I know what you mean. Did a check on the sound effects and the volume control wasn't working (barely audible). So dismantled control panel and found a dodgy connection on the potentiometer. Out with soldering iron and hey presto, loud sounds. Ian.
You aren't hanging around with this are you, it's looking pretty sweet! Great work
Guest (9)
