12 Pages «<678910>»
Jupiter by Occre Options
kpnuts
#141 Posted : 27 August 2015 21:40:34
Been a while since I looked in, wow love the caboose, it's all looking great.
#142 Posted : 03 September 2015 05:53:52
Thanks everyone.my spraybooth is still out of action so I went back to work on the boxcar since the caboose is ready for painting.
The next step for the boxcar was to install bars on the windows and grills for the vents on the front and back of the train.Next I installed the roof supports for the boxcar.I soaked the plywood roof and then taped it to a CO2 tank to get a curve on it.Once it had dried I installed it on the boxcar.I then put the boxcar and caboose on the track to see if they were the same height.
#143 Posted : 03 September 2015 08:40:49
BigGrin Very nice workCool
GilShapley
#144 Posted : 03 September 2015 09:14:09
Looking Good there Carl
Cant wait to see The Jupiter once your spray booth is back in action.
I have almost completed my Jupiter Build. I will at sometime build a freight wagon to complete the set but will leave this for a while. I feel the need for a change.
So I will be building the Eaglemoss Orrery once the parts start to arrive and also
have an Arab Dhow kit on the shelf
Gil
Current Build:-
#145 Posted : 03 September 2015 10:03:01
Looking good Carl, beautiful work! Cool
#146 Posted : 03 September 2015 15:42:49
Gil
Thanks everyone for your kind words as always
Gil your Jupiter looks fantastic.Looking at your build has inspired me to keep going on mine.It has been a bit of a drag at some points.This is a deceptively simple looking build, but it is actually quite challenging and it does require quite a wide range of skills from working with wood, metal and wire.The end is in sight though for me too.Once the roof on the boxcar is done and I have applied some stencils that will be finished.The caboose just needs painting and stencils and then the train and tender just need some touch up paintwork and I can start final assembly there too.
The final step will be the build the trestle bridge.
I should just about be done by Christmas
GilShapley
#147 Posted : 03 September 2015 16:57:14
Yes I certainly agree with the "deceptively easy" bit. For the beginner it aint
I must admit there where times when it was going on the back shelf but I am happy with the result so far
The worst part was not having to lean new skills, I am quite good with a ponce wheel now, but those damn transfers. Anyone who has attempted this build will know what I mean.In fact I have not used some of the transfers and replaced others with brass rods shaped as necessary
one mod I made was to add an additional borders of the roof of the cab to hide the join and make it a bit stronger as I have left it unglued so it can be removed to reveal the inside of the cab. This is facilitated by me not gluing on part K18. This just sits in situ but can be rotated out of the way if I want to remove the roof.
Another mode is both the side windows of the cab work in so far as they can be slid open.
I think the best word to describe this build is challenging
Current Build:-
kpnuts
#148 Posted : 03 September 2015 22:14:14
Loving the caboose all the extra work you are doing is great.
#149 Posted : 04 September 2015 08:20:59
BigGrin A challenge yes but both of you rose to the challenge and have done spectacular jobsCool
#150 Posted : 04 September 2015 13:28:08
Looks fantastic, and its nice to see how you overcome the challanges. top job
#151 Posted : 07 September 2015 07:06:24
Thanks everyone.More work on the boxcar.I finished the roof and attached the walkway and the ladders to access the roof.I also attached the brake wheel to the rear of the car.The next step is to paint the roof and then apply to stencils.
#152 Posted : 07 September 2015 07:12:56
More work on the caboose.I attached the walkway to the roof and started the rails on the front and back of the caboose.
GilShapley
#153 Posted : 07 September 2015 09:14:11
Nice work as always Carl
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
You got your spray booth up and working yet?
Current Build:-
greyhawk
#154 Posted : 07 September 2015 10:41:11
Wish I could see the pictures. Unfortunately the problem with forum attachments is getting worse all the time Crying
#155 Posted : 09 September 2015 06:06:27
Thanks guys,
my spraybooth is back in action, but it is really hot and humid here so I am waiting until the weather cools down.
I have added more detail to the caboose.It is ready for painting now.I just have to add the access ladders and stencils.
#156 Posted : 09 September 2015 07:31:36
Very neat and tidy.
Hope the weather changes, can`t wait to see this with a paint job.
Cool Cool Cool Cool Cool Cool
kpnuts
#157 Posted : 09 September 2015 09:12:24
Wow looking great.
#158 Posted : 21 September 2015 05:45:58
More work on the boxcar.I bought some dry transfer letters to add some detail. I thought they would be easy to apply, but they were terrible.They did not transfer well so after some frustration I came up with a way to get them to work.I placed the letters onto some Tamiya tape and then I could attach them to the boxcar with the tape and keep peeling the tape back and forth checking that they hade transferred.it was pretty tedious work, but it worked pretty well.
#159 Posted : 21 September 2015 06:01:08
The caboose in being painted so I figured it was a good chance to make some signal lamps.I made them with a couple of different diameters of wood dowel, some MV lenses and Tamiya clear red and green paint.
kpnuts
#160 Posted : 21 September 2015 06:47:31
Super work liking this a lot
Guest (18)
12 Pages «<678910>»
This page was generated in 0.920 seconds.
