10 Pages «<34567>»
Stug IV with full interior + extras and dio Options
#81 Posted : 30 August 2015 22:43:10
Some more done, the main gun has been painted and dirtied up internally and the muzzle brake fitted. The wheels have all been made up next and undercoated then it was time to start on the fenders. I have always liked Griffon etch some say its too flimsy but when its assembled its quite strong and generally its made in the same sections as would the full size item. So angle brackets both sides and 3 sections to form the main fender along with the cross braces. This is where a good etch bender is a must for the angle brackets. There are still the front and rear sections to add here. The final pic is of the gun and front upper hull in place just to show it all fitsDrool Flapper Flapper LOL LOL . The dio base has also been undercoated ready for painting but more on that later.
#82 Posted : 30 August 2015 22:46:41
Nice work on the pe, are you going to bend it up to make it look damaged?BigGrin
#83 Posted : 30 August 2015 23:07:42
BigGrin HI Nem
I may do a little on the rear and front but the sides will have the hanging plate armour so little point for the centre sections apart from the fact that I also have the full resin stowage set from 'Ledgend' to go on aswell so a lot of side damage would end up being covered anyway. Thanks for looking in and your comments.
#84 Posted : 31 August 2015 21:04:22
Made up the forward fenders, Im getting quite the expert making miniature working hinges now. The front upper hull and the rear engine cover has also been added the front and rear covers are still removable apart from the drivers compartment as the figure set I have the driver has no legs so cant be used on this model but the other crew can and will be. The main gun has also been fixed in place after painting around the upper hull where the mantle fits and some shells added to the racks. Still loads more etch to go on and I have included a pic of the undercoated Dio base , more soon.
#85 Posted : 31 August 2015 23:22:12
Beautiful work Andy! Your etch looks so clean, can't wait to see the rest of it go on Cool
#86 Posted : 01 September 2015 20:22:49
BigGrin BigGrin Hi Dave
Thanks for looking in and your comments, I promise you the etch looks cleaner than it really is. On the tiny bolt heads I will use paint to stick them in place.
#87 Posted : 02 September 2015 10:37:46
Nice work Andy, looking good. Cool ThumpUp
#88 Posted : 02 September 2015 11:14:10
BigGrin Hi Kev
#89 Posted : 02 September 2015 22:36:11
More done, the rear fenders are now attached to the hull and the etch weld seams added to the exhaust's the main roof is on and masked ready for spraying, more bolt heads small brackets and panels added to the front and the spare wheels box added to the side hull, there is a bar still to go on this part. more soon.
#90 Posted : 03 September 2015 08:56:04
Very nice work on the etch, always seems a shame to paint it!! This is gonna look so cool when its done!!Drool BigGrin
#91 Posted : 03 September 2015 10:07:50
Blink Blink A lot of tiny etch on shown there, awesome work Cool
#92 Posted : 03 September 2015 19:25:57
BigGrin Thanks for looking in and your comments, still making up the tool brackets right now Blink Drool LOL Cool
#93 Posted : 03 September 2015 21:09:50
#94 Posted : 03 September 2015 23:02:10
BigGrin Hi Steve, Thanks for your comments and looking inCool
#95 Posted : 03 September 2015 23:10:44
BigGrin BigGrin Hi All
Bit more added with the etch added the rear hooks and chain for the towing hawser then the wooden block for the jack has been added along side the wheel rack, you can also see the weld seam by the cupola. Next the tool fasteners have been added to one side of the fender the tools will still come off for painting. To come is the tools on the other side and then the hanging armour braces plus the stowage rack. more soon.
#96 Posted : 03 September 2015 23:24:08
Very nice indeed, a fantastic build to watch!BigGrin BigGrin
#97 Posted : 03 September 2015 23:58:37
Thats a nice load of etch going on Blink Ive just noticed the etch weld seams, not seen them before, they look pretty cool Cool
nightwisher
#98 Posted : 04 September 2015 00:14:50
Some excellent Etch work going on, have only done a bit of etch myself and it did my head in. Cool
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#99 Posted : 04 September 2015 08:42:56
BigGrin Thanks everyone for looking in and your commentsCool
#100 Posted : 04 September 2015 12:45:03
Very impressive etch work there Andy, should look stunning when finished - well done. Cool ThumpUp
Guest (10)
10 Pages «<34567>»
This page was generated in 0.643 seconds.
