Got my first Pack 1 stages 1-10 I have a small Question Options
eebygum
#1 Posted : 05 September 2015 10:40:24
Got my first pack I was wondering is it worth doing the 12 Pdr and Anchor now or just collecting them and doing them as a batch same as the carronade?
thank you
#2 Posted : 05 September 2015 10:51:29
Very pleased to hear you have received your first pack and are ready to start building. The construction of the cannons and carronade is entirely your choice, some builders do them in batches, others do them as they come and some leave the lot as one big lot. You will however need 10 of them to start with to fit in Pack 4, prior to fitting the main deck so if it were me I'd wait until you have 10 then build these as a job lot.....Cool Cool .. Good luck with the build, look forward to seeing how you progress...
eebygum
#3 Posted : 05 September 2015 10:58:53
Hi thanks for the advice sounds good to me. On with the build then!
#4 Posted : 05 September 2015 13:33:51
BigGrin Welcome to the forum and looking forward to seeing your build Cool
#5 Posted : 05 September 2015 14:15:32
Welcome to the forum eebygum....Hope you enjoy your build...Wink ThumpUp
greyhawk
#6 Posted : 05 September 2015 18:05:04
Personally even though I do have the complete kit, I do everything "by the book" doing a cannon with issue 1 then again with 14. I have found this to make sense, as these little "in between projects" provide valuable practice and experience at least for me as a total noob with woodwork.
#7 Posted : 05 September 2015 20:40:15
Welcome to the Forum mate. Look forward to seeing your build progress.BigGrin
#8 Posted : 07 September 2015 13:17:46
Hi eebygum.
look forward to seeing your build.
In issue 1 the cannon base was round the wrong way. should be thin end to the ffront and wider part of base to the breach of the gun. i think they changed it round in issue 15. i made the mistake of doimg it the other hope this helps you. Ian
eebygum
#9 Posted : 07 September 2015 13:32:14
Ian Thank you I will look out for that
#10 Posted : 07 September 2015 13:46:32
The cannon build in issue 1 has been corrected in the build sequence for the 12 month instructions, although there are a couple of supplementary images that still show it the wrong way round.
This page was generated in 0.065 seconds.
