 Rank: Pro  Groups: Registered
Joined: 04/07/2015 Posts: 99 Points: 309 Location: north wales
....and next issue another good chunk of the underside hull.... adriuus attached the following image(s):
Joined: 25/05/2015 Posts: 66 Points: 204 Location: Minneapolis
It's great fun to see your Falcon develop. You're having a lot of success with your approach. Thanks for sharing, and looking forward to seeing more. It's good to see what's ahead too.
Joined: 04/09/2015 Posts: 92 Points: 256 Location: Atlantis
Absolutely beautiful work on the hull paint and the weathering. Really first class. I am delighted to hear that you are having good luck with the DOA paints. I haven't started my build yet but I went ahead and purchased the DOA paints and your terrific paintwork confirms my decision to go with these. Very inspiring!
Thanks for your comments guys.....yes i can heartily recommend the DOA paints... Tried vallejo and got on okay but in the 2 different repaints i did first , i couldnt get the look or the colouring i was after..... DOA saved my sanity !!!!!!
more of the underside hull coming together.....some really nice detailing on these parts...its funny to recognise little kitbashed parts on the model which have been faithfully reproduced....next week we get the main area of the ramp section and some lighting parts which look like they illuminate the ramp when its open...which if I'm correct about it will be a nice touch.... adriuus attached the following image(s):
Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Really fantastic work, it's great to see what we will be getting. I think you should do a YouTube tutorial Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Just gets better and better. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Lovely work Adriuus, the weathering looks pretty spot, not too over the top
I agree. Definitely not overdone but terribly realistic. Great job.
 Stunning weathering very nice Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
many thanks for your kind comments again....this week saw the start of the ramp parts ....so just a few pics of it as it stands at the moment....also been working on ideas of eventually displaying the falcon "in flight" ... not keen on the deagostini wall mount which will cover most of the underside up. using the already included screw holes in the hull for the wall mount ,I've been trying out ways of using these for rods to support the model ....not keen on the metal rods seen in the pictures ....they look a bit "war of the worlds"!!!...now looking at Perspex rods or trying to figure out a way of using the bottom turret window as a mounting hole.. made a display table too which at the moment is bare bones and also part work bench while constructing the falcon....was going to use the bottom section for storing the magazines etc but now the underside will be the display section for the back to the future delorean which ive just subscribed to....the missus will kill me !!!!! keep up the great work everyone... adriuus attached the following image(s):
Looking good Ade Liking your alternative method of displaying, don't forget the finished thing will weigh in at about 11kgs
well its been a while since I updated ....the ramp building was a bit uneventful as the power for the motor has not yet been supplied...so it remains sealed shut....the hull plating is now almost full circle though !!! one thing to note on the latest section of hull plating is the small hole hidden in the "battle scar"...not sure what this is for but have a feeling it may be to conceal a switch or button for controlling either the ramp or lighting... as I have been layed up with man flu I also started tinkering with the hold again ...added a few bits , cut the seat backs down etc...much more satisfied with the look now...still a couple of bits to add which are on their way. also waiting on delivery of the revised tp1 and tp2 parts from france...will post some pics when they arrive... issue 40 contained the revised nose cone which after a bit of tinkering with the window frames looks pretty good..and it is definitely an improvement on the original . that's all for now...keep up the great work everyone adriuus attached the following image(s):
couldn't resist adding this to the hold....a bit of fun !!! adriuus attached the following image(s):
Great addition! Looks like C3PO has seen better days.
Very nice add on. I like it!
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Nice detailing. Where did you get C-3PO? He looks perfect for the model. Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Thanks... C3P0 is by tengel on shapeways
hi everyone progress on the falcon has been a bit slow the last few weeks....deagostini have had major distribution problems and so the magazine hasn't been getting into stores...hopefully this week things will return to normal !!!! however.... when I got the revised hull plating pieces tp1 and 2 from france I ended up with all the cockpit innards again which with the new nose cone got me tinkering...ordered the paragrafix etch set for the cockpit and went for it...even had a go at fibre optics which is a big leap for me !!! very pleased with how its turned out and here are some pics of the old and new cockpit... cheers for now and keep up the great work all... adriuus attached the following image(s):
Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Very nice bro... love the detail work you've done so far!
Guest (7)
