5 Pages «<345
Stevie's Red Arrows Presentation Options
#81 Posted : 19 March 2015 12:20:49
Thanks for lookingBigGrin
Here's the results of the home made tail decal. The decal paper was a little bit thicker than the standard decals so took some softening to get it to lay flat.
It looks nice though as no red shows through it, which is my concern for the other kit decals.
#82 Posted : 19 March 2015 14:46:28
Those decals do look very nice ThumpUp
#83 Posted : 22 March 2015 09:48:54
Hi Steve, BigGrin
Neat work on the decals. Cool
#84 Posted : 22 March 2015 11:20:43
Lovely work Steve, the decals really have turned out exceptionally well, very well done....Cool Cool
#85 Posted : 22 March 2015 11:45:26
Nice work Steve, not easy to mask wavey lines but you've done a good job with it - well done, it looks great. Cool ThumpUp
#86 Posted : 22 March 2015 11:59:38
Lovely build you have coming along.
Very well done on the red finish which has gone on well. For some reason I have never found red to be a colour that I could ever get right when I have used it.
Yours look top notch.
#87 Posted : 08 April 2015 14:17:01
Thanks for watchingBigGrin
Upper decals done, underside not yet done. They went on ok with some decal solvent and have been airbrushed satin varnish to seal. Next job is either the canopy or landing gear, not sure yetBigGrin
#88 Posted : 08 April 2015 18:10:47
Its really starting to look the part now, and a rather nice part it is too Cool ThumpUp
#89 Posted : 08 April 2015 22:48:56
Hi Steve, BigGrin
Looking spot on. The tail decals look fine.
Waiting for the next update. Cool
#90 Posted : 08 April 2015 23:44:10
Impressive Stevie and you can certainly see the care and attention you have put into this.... Beautiful work to date.....Drool Drool
Gibbo
#91 Posted : 09 April 2015 13:32:58
Looking really good Steve, new tail fin looks fantastic.
Paul
#92 Posted : 06 September 2015 16:37:12
Back on the Hawk after a long breakBigGrin
Firstly I have applied a couple more coats of lacquer to the upper surfaces. I wont be clear coating the underside just yet as the decals are not finished - there is also the smoke pod and air brake to add underneath.
Finally got the main parts of the undercarriage done, just the legs. There are also some struts and bay covers to attach but that's all for later.
I added some more detail to the legs using some wire for the main hoses and a couple of peices of etch too, plus I replaced the inner suspension with some short cuts of metal.
The tyres were weighted by warming them up and pressing on to a hard surface and I have also airbrushed a grey wash over the part that would be in contact with the tarmac.
A little weathering of panel liner and some brown wash for the greased areas and they were done.
The main canopy decals are also completeBigGrin The more observant among you will also notice that the front part of the canopy that was fitted previously is now missing, I had a reaction between the clear coat that was on there and the lacquer that went over the top and it crazed all over.
I had to carefully cut it out with a scalpal, luckily I have another of these kits to nick parts fromLaugh More soon hopefully.
#93 Posted : 06 September 2015 17:26:10
BigGrin Very nice and starting to look the partCool Cool
#94 Posted : 06 September 2015 18:35:43
I had forgotten this build. Absolutely stunning work. Your attention to detail is fantastic, I tip my cap to you sir!!Love Drool ThumpUp BigGrin
#95 Posted : 06 September 2015 19:12:36
Beautiful job Stevie, there's nothing that speaks 'class' for an aircraft on the ground than undercarriage that looks like it actually works! I also tried the 'heated wheels' trick on a part of my diorama, unfortunately mine were polythene not styrene - not the best idea I had on that one!Crying(Though I was very pleased with the 'recovery'!)BigGrin
Keep these coming, looking great!Cool
#96 Posted : 06 September 2015 21:43:44
Im loving your Red Arrows build Steve, the landing gear and tyres look amazing with the weathering ThumpUp
#97 Posted : 06 September 2015 23:49:42
This build gets better and better. loving your perfectionist approach to it all, its paying of big time.
#98 Posted : 07 September 2015 17:40:06
Very nice indeed Steve and great work on the undercarriage, looks very realistic. Love the photo of the canopy, which is very nicely built too - well done. Cool ThumpUp
#99 Posted : 07 September 2015 23:21:52
Guest (15)
5 Pages «<345
This page was generated in 0.280 seconds.
