pack 17 fuel pipes Options
Steve279021
#1 Posted : 10 September 2015 07:57:54
Are they as tricky as they look?
Dodge charger build complete
Warthog
#2 Posted : 10 September 2015 11:20:58
Not if you follow the instructions and/or the official build diary properly BigGrin
Spencer
Steve279021
#3 Posted : 11 September 2015 15:04:47
Well the fuel rail is done with all 6 pipes attached. Just need to fit it to the engine now!
Captain Plummet
#4 Posted : 13 September 2015 16:48:34
You will find that that IS the tricky part... BigGrin
Sticking them onto the engine looks dead simple, but I found that a) I really needed those explanatory diagrams in the instructions, because weaving the hoses round the injectors was, um, challenging, and b) even when you have them where they should be they will always want to spring back out of where you need to glue them. Be prepared to have sore fingers from holding them in for ages while the so-called 'instant' glue takes ages to go off.
Steve279021
#5 Posted : 13 September 2015 17:49:34
You're right, that WAS the tricky part and it took me a while but it's all done now.
ian2014
#6 Posted : 13 September 2015 21:08:03
By the looks of it think we are all at same stage not looking forward to glueing to engine at all .
Facebook-model maker
ian2014
#7 Posted : 29 September 2015 13:44:59
I take my hat off to all the people that have done fuel pipes.
#8 Posted : 15 June 2020 04:09:35
I apologize for bringing a topic from the dead. But I am currently here and it seems to be quite challenging and after reading comments here I see IT IS quite challenging. Did anyone figure out an easier way to do it? I have feeling that 6 houses that will go to the fuel rail have to be twisted as well, to match angle on which they are going into the injectors. Should I try to be smart and I find a new way, or just do as they say and hold 6 ends one by one to an injector until adhesive doesn't do its job?
This page was generated in 1.195 seconds.
