4 Pages 123>»
Hachette tiger tank Options
billbo
#1 Posted : 10 September 2015 20:07:49
Hi just like to let you know il be starting a diary soon on this monster of a tank i did start this colection few years ago got to issue 30 then ran out of fund then had no use and binned it bad mistake so spent few months searching ebay and got lucky and got most the colection for 200£ witch i thought was a bargin only have issue 1-123 so will have to hope i can get the last few issues some were will probly go down the leave the model open route instead of screwing it all down and never seing the inside again
building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
#2 Posted : 10 September 2015 22:42:19
Sweet another build the this monster, I couldnt believe the amount of plastic and metal in the box when I got mine.
Fingers crosses you find the last issues and loo forward to seeing your build Cool
#3 Posted : 10 September 2015 23:40:41
Hachettepartworks.com has quite a few of the later parts showing in stock.
#4 Posted : 11 September 2015 00:30:01
She is indeed a huge build and I look forward to following your progress.... good luck with the build....Cool Cool
greyhawk
#5 Posted : 11 September 2015 01:57:34
billbo
#6 Posted : 16 September 2015 13:53:45
Quick question whats the best way to paint the tracks links conect all together or one at a time
#7 Posted : 16 September 2015 15:43:57
Personally I would paint them once assembledas the easier method. You could paint prior to assembly but you would more than likely need to apply some touch up once assembled.
billbo
#8 Posted : 16 September 2015 15:46:37
Yeah that what i was thinking whats the best way to remove that silver paint on it would rubing alchol work
#9 Posted : 16 September 2015 18:27:21
BigGrin I always assemble my Friul tracks then paint with Tamiya metalic grey XF-56 and would reccomend this way to anyoneCool
#10 Posted : 16 September 2015 19:45:11
Excellent, another Tiger!!! I assembled the tracks and then painted them. I use a base coat of Tamiya Red Brown on tracks. Check my tiger build to see how i did them.BigGrin BigGrin BigGrin
billbo
#11 Posted : 19 September 2015 22:05:37
I was looking for red oxide spray as i dont have a air brush and i cant find any what would i be looking for thanks
#12 Posted : 19 September 2015 23:03:19
BigGrin Here you go,
http://www.wickes.co.uk/...ay-Paint-400ml/p/194167
Not cheap but should cover a fair amount of metal, its also not acrylic based so ventilation may be in order.
Or you could use Tamiya's flat red brown TS-1,
https://www.wonderlandmo.../tamiya-ts-1-red-brown/
#13 Posted : 20 September 2015 14:08:38
I use Simoniz Red Oxide, works well.BigGrin
billbo
#14 Posted : 21 September 2015 19:43:33
Been dry fitting the hull and have found a problem with the rear wall anyone had this
billbo
#15 Posted : 21 September 2015 19:54:25
#16 Posted : 22 September 2015 08:40:16
Didnt have a problem with mine.
#17 Posted : 22 September 2015 08:46:28
Haven't tried mine yet but looks like some filler would.sort that nicely Cool
billbo
#18 Posted : 22 September 2015 10:52:33
Seems that the bottom is longer than what it is ment to be but it might just be me. I thought that it should off been flush as it has been angled and the wall has been angled for it to fit flush.might be a case of sanding it fown abit
billbo
#19 Posted : 22 September 2015 10:56:16
. This is a better photo
billbo
#20 Posted : 22 September 2015 17:43:49
After dry fiting the turret walls to the turret ring everything is not lining up have to say the turret desighn is not the best desighn ever. After filing and cutting away at the ring still not a great fit another issue of the turret ring on the way hope i have better luck with this one
4 Pages 123>»
