Hi walter. Looking vcery nice. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi guys, thanks again for your comments!
I want to show you the next update with the now completed base of the gallery.
As i mentioned before i don`t follow the instructions regarding the Gallery - do a little scratch build instead.
I bent some wooden profiles to simulate the real thing:As the next step i will give the lower hull a few coats of semi-gloss varnish to seal it. And then - and i`m very excited about that - after about two years she will leave the "upside-down"-jig and be put in her upright position at last! I will then work my way up at the gallery, which again will pose a lot of challenges - especially because of the different height of the windows at the side parts and the rear part of the gallery.
Thanks for looking in, DaDokta attached the following image(s): Greetings, Walter
Beautiful. You must be very proud.
 Lovely work on the gallery Walter very nice Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Outstanding work Walter, she looks fantastic
Looking great Walter, credit to your skills.... Regards Alan
Brilliant work there Walter, your patience and hard work are paying off. Well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi guys! It`s been a year - and after a move and after completing my McLaren and D-51 build i will now again continue my Victory.
As mentioned before, i try to build the gallery and transom as near to the original as possible with my skills.
Earlier in the build i decided to use the enhancement transom part but stay with the side-gallery parts as they came with the partwork (the reasons for that have been discussed in extenso :-) ).
As i used different wood profiles for the gallery-linings, the different heights of the windows caused a lot of problems and each step took much consideration and time. I had to settle down for some compromises, as you can see in the pics.
So let me show you, where i am at:
As much as the side-gallery windows are sitting in the right height (compared to the deck height) using the original parts, they still are too big in height themselves in my opinion (i hope my english is understandable). So i attached the next wood-profile a liitle bit lower to reduce the height and to be able to connect with the profile on the transom as properly as possible:After each step multiple rounds of tydiing up and painting! As i will show you in upcoming posts, i had (and will have) to adjust the photoedge parts of the pillars (?)as when using wood profiles instead of the photoedge only, these parts are much too big.I tried to simulte the decorations on the inside of the bulwarks with some twisted wire - i`m afraid it didn`t quite turn out as perfect as i would have wanted to, but it still is a nice effect in my opinion:As always thanks for looking in![/size] DaDokta attached the following image(s): Greetings, Walter
Looking great. Some very nice changes you've done, your efforts are paying off... Regards Alan
 Looking good Walter very nicely done Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Very nice update Walter, and good to see you back at it Steve
Thanks guys!
Here`s my next update. I added the first row of pillars - as mentioned before i had to adjust the height of the pillars to fit properly. Also some of the decorations were added and the next wood profiles attached:DaDokta attached the following image(s): Greetings, Walter
Hi Walter, Class work again very nice. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Added some decorations:DaDokta attached the following image(s): Greetings, Walter
Added further decorations (unfortunately the center decoration piece was broken when i opened the box) and moved on to the side-galleries:DaDokta attached the following image(s): Greetings, Walter
Looking good Walter A bit of epoxy should sort the broken decoration out, it looks to be a clean break
Hi Walter, That was a tricky part to assemble with the different sizes to match up,but it looks great. Well done Walter Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Walter Your build is looking very nice. Amazing just how many parts go to make up the stern of the ship but all looking very good indeed. Happy Modelling
Lovely work Walter, doing a great job with the gallery.... Regards Alan
Lovely work Walter, it gets better and better Steve
Guest (22)
