4 Pages <1234>
Hachette tiger tank Options
billbo
#21 Posted : 23 September 2015 10:53:58
THIS MY MODEL SO FAR HAVE DONE THE TOP HULL ALL READY TO BE PRIMED AND SPRAYED.HAVE TO ORDER SOME SPRAY PAINT FRIDAY AS I DONT OWN A AIRBRUSH
building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
billbo
#22 Posted : 23 September 2015 10:57:29
THE GUN IS COMPLETE READY TO BE PRIMED AND PAINTED I HAVE TO ORDER A NEW ISSUE OFF THE BREACH AS I TRYED TO PAINT IT WITHOUT PRIMER AND WHAT I MESS OF IT I MADE SO I GAVE UP SAME ON THE RECOIL DAMPERS Crying
billbo
#23 Posted : 23 September 2015 11:04:49
ONE SETS OF LINKS COMPLETE THE OTHER ALMOST AS NEED TO ORDER LAST 11 MAGAZINES TO COMPLETE THIS MODEL ALSO I HAVE TO ORDER A NEW TURRET RING AS THE WALLS WERE A POOR FIT AND I HAD TO SAND AND FILE FOR THEM TO FIT BUT I KIND OF WENT OVER BORED AND BROKE IT LOL
billbo
#24 Posted : 23 September 2015 11:11:34
HERE IS THE COMPLETE LOWER HULL JUST SCREWED IN LIGHTLY ONE OFF REAR SCREW HAVE STRIPPED SO COULD BE A CASE OF SUPER GLUE WHEN PAINTED ALSO HAVE PUT THE TOP ON TO SHOW YOU THE SCALE ABIT HAVENT BEEN DOING TANK IN ORDER
#25 Posted : 23 September 2015 12:30:08
Looking good Bilbo, it's certainly a beast and weighs a fair amount.
When I got mine I was debating if I should use the airbrush when I start or spray cans due to the size Blink
billbo
#26 Posted : 23 September 2015 12:44:01
Yeah its a fair size was debating to get a airbrush but il stick to spray cans chrismas not far away santa might be good to me BigGrin also spray would cover more area for this model. Iam thinking of weathering it but iam never done weathering before and i dont fancy destroying a good paint job.
greyhawk
#27 Posted : 23 September 2015 13:44:05
I went for the airbrush. I have the feeling Spraycan paint always comes out a bit thicker than when I airbrush and I didn't want to loose detail on the zimmerit.
billbo
#28 Posted : 28 September 2015 16:04:34
GOT MY NEW ISSUE OFF THE TURRET RING AS OTHER ONE BROKE HAD MORE LUCK WITH THIS ONE THE WALLS FITED STILL MASSIVE GAPS IN THE WALLS BUT THEY CLOSE UP WHEN THE ROOF IS ON NOT SURE TO EPOXY THE WALLS TOGETHER TO STOP THE GAPS WHEN ROOF IS REMOVED AS I LIKE TO HAVE THE MODEL SO YOU CAN SEE INSIDE
#29 Posted : 28 September 2015 17:02:54
Glad you got the gap issue sorted. I would definitely go with the epoxy route if you want to take the roof off for display, would look so much better that way Cool
#30 Posted : 28 September 2015 20:24:11
If you look at my build you will see how I did the turret as a cut the post out so I could take the roof off. I didnt use any glue, just the screws and then filled the gaps on the outside.BigGrin
billbo
#31 Posted : 07 October 2015 15:37:20
WELL WITH THE BAD WEATHER I THOUGHT I WOULD LET MY SELF LOSSE WITH SOME PRIMER AND COAT SOME PART WILE I WAIT FOR MY ORDER OFF DESERT YELLOW SPRAY PAINT
#32 Posted : 07 October 2015 19:26:29
Looking good, miss building mine now!!!LOL BigGrin BigGrin
#33 Posted : 07 October 2015 21:31:27
Looks cool, makes me want to pull mine out and start on it but I just have too much going on at the moment to start another one. I dont want to start falling into the trap of not finishing anything Cool
billbo
#34 Posted : 07 October 2015 22:17:56
Yeah i have not much time on my hand with work right now as getting near xmas joys of working in tesco bakery have 3 models going at the same time have yamato,u96 and now the tiger
#35 Posted : 08 October 2015 00:12:01
You may not have a lot of time but she is certainly progressing nicely.... well done, look forward to your next update....Cool Cool
billbo
#36 Posted : 12 November 2015 15:26:06
Sorry i have not been progressing to well been busy with work also dont help that christmas is almost apon us again. I havent done to much weather has not been in it to get outside and get some spray painting done but managed to get out to day before the storm hits us latter i have used humbrol desert yellow and the hull inside is red oxide primer. Hull almost ready to get glued together as you can see i have not been doing the build in order i have jumped back and forth isues fell free to leave coments thanks
greyhawk
#37 Posted : 12 November 2015 18:27:35
#38 Posted : 12 November 2015 18:51:36
Looking good, I think I will be jumping around the order of the build myself when I start mine, that's one of the advantages I guess of having the full kit Cool
#39 Posted : 12 November 2015 19:00:48
That is coming along really well! I didn't build mine in the order they said, found it easier to be honest!BigGrin BigGrin
billbo
#40 Posted : 03 December 2015 16:00:01
Not much done here but have been picking away at the beast. Have sprayed most the parts in desert yellow 88mm gun is now compleate with breach i have used matt white instead of ivory as i cant get it in spray form and dont have air brush maybe santa be nice to me.
4 Pages <1234>
This page was generated in 0.289 seconds.
