2 Pages 12>
Stevie's T-70M early soviet light tank build Options
#1 Posted : 23 September 2015 12:00:57
Well, Andy's Stug build has inspired me to delve into the stash and pull this out - I actually pulled out 3 kits, the Academy Grant and Academy Hetzer but this one got the voteBigGrin
My wife has gone on hols to Turkey with my eldest daughter and there somehow seems less work to do around the house when she isnt hereBigGrin So this is a time filler while shes away!
I plan to set this on a very small base in winter scene of the Russian/German front 1943, but we will see how that goes. BTW, the kit supplied 5 tank crew figures but these only had a 2 man crew so I wont be using them all.
I have the Eduard etch for this but no aftermarket tracks, only the kit separate links supplied, no rubber band tracks either. The kit itself is very simple and wont take long at all if you dont include track links, so I will most likely build this in one day and post the progress pics all at once.
It's the painting and weathering of the winter cammo that will take the time on this oneBigGrin
Hope to update this post later with the basic build complete.
#2 Posted : 23 September 2015 12:11:27
BigGrin Looking forward to this one Steve Cool
#3 Posted : 23 September 2015 12:26:12
Oooh house to yourself, hope your wife doesn't read your post LOL LOL
Look forward to seeing your weathering process as I'm soaking up all the tank weathering info I can at the moment BigGrin
#4 Posted : 24 September 2015 17:09:02
Didnt get as far as I planned - other things got in the way. But, I also found an ancient Tamiya Panzer II in my stash so this is going on the same base in a knocked out stateLaugh I dont have any etch for it so it will be an enjoyable out of the box build (apart from a bit of damage). Im going to build these 2 in together doing a bit to each one in each session - might do some gradual work on the base too during the build as I always lose interest in the scenics after the model is complete.
The pics below show where I am now, note the warped deck on the T-70Laugh
#5 Posted : 24 September 2015 18:11:20
Nice start Steve and even better now with the second one going in the dip too BigGrin Cool
#6 Posted : 24 September 2015 19:16:08
BigGrin Nice start SteveCool
#7 Posted : 24 September 2015 20:07:04
Hi good to see you made start on them both now.looking good.look forward to next update.cheers mick.BigGrin BigGrin
#8 Posted : 24 September 2015 20:09:20
Thats a cool build, looking forward to this one!!BigGrin BigGrin
#9 Posted : 25 September 2015 20:48:46
Well, I thought Id change the plan, I was going to build these side by side throughout the build but got carried away on the Panzer, I think is was because it was so nice just to build with no interruptions with adding photo etch.
The panzer as said earlier is going to be knocked out with track damage and a couple or three shell holes from a 76mm T-34 having a pop at it. I planned on having the tank blocking the T-70's progress on a mud road.
Anyway, the panzer is nearly complete - I will move on tomorrow with some filter layers to tone it all down, paint the tools, add some fresher rust (more orange) tracks, satin coat and of course the damage. I have some pics of shell damage and the holes are surprisingly small so I plan on one hit on a wheel with scarring and a track break and another hit maybe under the fender.
So the pics below show it as is, bear in mind that the filters will blend things in a bit better tomorrow, mud and pigments wont be added until I have the dio mud colour sorted.BigGrin
I wanted very heavy weathering on the dead tank, the T-70 will be a bit lighter (not by much though)
#10 Posted : 25 September 2015 21:07:17
BigGrin Looking good Stevie loving the weathering BigGrin
#11 Posted : 25 September 2015 23:07:11
Looks fantastic Steve, I really love the heavy weathering you've done Cool
#12 Posted : 25 September 2015 23:53:56
Looking great Steve, very nice work as usual....Drool Drool
#13 Posted : 26 September 2015 10:07:10
BigGrin Nicely doneCool
#14 Posted : 26 September 2015 17:17:37
Thanks guys,
The Panzer is done apart from the tools and perhaps some graphite highlights. It's not the main focal point of the dio so I'm happy as it is as it will also have some snow on it too. Still trying to decide if I should put a shell hole in it somewhere?.
I will be continuing the T70 nextBigGrin Thanks for looking.
#15 Posted : 26 September 2015 17:37:23
Looks really cool Steve Cool how about a shell hole in the front idler where the track is broken, that would look good I reckon?
#16 Posted : 27 September 2015 00:55:26
Looks fab Steve....Drool Drool
#17 Posted : 27 September 2015 01:58:03
BigGrin I would remove the front wheel where the track is broken and reproduce damage there as the doctrine of the time for anti-tank gunners was to blow off the tracks first then blow up the tank when it couldnt move. If the first shot was on target this usually removed the front traction gear that usually splayed the vehicle side on for an easy thin side armour shot.
#18 Posted : 27 September 2015 18:44:23
TanksBigGrinfor looking in. Cheers for the suggestions too, taken on board! I have now made a hole in the front sprocket and through to the hull, the sprocket will eventually be lying next to the tank. OK, it is a big hole so I reckon a KV-2 done itFlapper
I can now get on with the T-70 build.
#19 Posted : 27 September 2015 19:15:38
Hi Steve looking real good there.luv the weathering on the panther, she certainly seen some service at for sure.look forward to more cheers mick.BigGrin BigGrin
#20 Posted : 27 September 2015 23:10:14
Looks perfect Steve Cool
2 Pages 12>
This page was generated in 0.271 seconds.
