Joined: 16/06/2014 Posts: 65 Points: 188 Location: Austin, USA
I can't believe that I haven't posted in almost a year. Almost time for the USGP again. Anyways, I just finished Pack 20. The car is really coming along nicely now. One more pack and I could technically start it up, albeit with no servo based throttle control. Maybe I could run a few tanks in to set the idle screw :) Here is a pic:
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Looking good there. I have just subscribed to this so looking forward to my first pack. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Thanks! You will have fun with it. Very different than any other modeling I have done before.
Speaking of fuel, anyone have any suggestions on which Nitro fuel to get with the stock R5 plug. I was thinking 20% would be a good happy medium, but what are you guys running?
15-20% is fine, but remember that that higher % you go, the faster the wear of the engine.
Joined: 23/07/2013 Posts: 120 Points: 336 Location: Brisbane Australia
Looking good. I'm glad to see I'm not the only one taking a while to do this build. Chasecar
I just saw something in the official build diary that I didn't do because it wasn't in the magazine instructions. When installing the clutch bearing, the magazine just says to put grease on the bearing after you slide it on to the shaft. In the build diary you put grease on the shaft and the outside of the bearing. Will I have a problem if there is no grease on the shaft itself as well?
Thanks.
 Rank: Pro  Groups: Joined: 11/04/2013 Posts: 119 Points: 347
I'm sure the grease on the outside of the bearing will be fine, i'd say the grease will make its way onto the shaft as well anyway.
Awesome! I think I'm going to start my build in the new year. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Also wanted to say thanks to Tomick for the official build diary. The paint colors that you have suggested look amazing so far on the parts I have painted!! Thank you!
Got the racing body painted. 1 more Pack Left!
Joined: 30/11/2015 Posts: 57 Points: 180 Location: Beds
Well done  Looking good only a couple of hours to go
Almost done with the running body. Still need to paint the front wing stays and the rear tyre aero components as well as the running rear wing and bargeboards. It is coming together nicely. I have the 2 speed gearbox on the way from the UK as well. It will be fun to finally run it with the body on it!
All done with the Running setup. I finished the decals for the display body as well. making sure it is good and dry before clear coating then its all done. I do have the extension on its way as well. Here is a video of a test drive yesterday. I was being very cautious, as the road was too narrow to not accidentally hit a curb. I will take it to a big parking lot soon to open it up. https://www.youtube.com/watch?v=Ufo64mN3kqY
That looks some great fun. Hope you had lots of fun with the build and get as much fun from running it. Very well done Happy Modelling
A job well done. Very interested to see it opened up in a big space. How about a few pictures in the "Finished build gallery" Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks y'all. I will take some good pictures for the finished build gallery once I have the 2 speed in and the display body clear coated.
