8 Pages «<23456>»
Graham's CB750 Build Options
#61 Posted : 30 September 2015 20:38:07
BigGrin Looks good and the weight is starting to grow now too I thinkCool
#62 Posted : 30 September 2015 22:18:00
Great update, its all coming together nicely Cool
bugsec
#63 Posted : 01 October 2015 22:13:03
Thanks guys.
And yes it is getting a bit heavy picked up the box I'm using to store the parts and almost gave myself a hernia! BigGrin
bugsec
#64 Posted : 01 October 2015 22:44:14
Pack 13 contains Stages 41 - 44
Stage 41 - The cylinder head top and cover.
Parts supplied: Cylinder head top.
Also required: Cylinder head cover (Stage 11).
Not much to do with this stage just placing the parts together and holding in place with masking tape.
bugsec attached the following image(s):
bugsec
#65 Posted : 01 October 2015 22:45:13
Stage 42 - The cylinder head.
Parts supplied: Cylinder head.
Also required: Cylinder head top (Stage 41).
Again not much to do with this stage just placing the parts together and holding in place with masking tape.
bugsec
#66 Posted : 01 October 2015 22:46:15
Stage 43 - The cylinders.
Parts supplied: Cylinders, Tension holder and screws.
Also required: Crankcase (Stage 40) and Cylinder head assembly (Stage 42).
bugsec
#67 Posted : 01 October 2015 22:47:21
Stage 44 - The crankcase bottom.
Parts supplied: Crankcase bottom, Oil filter case and screws.
Also required: Crankcase (Stage 43).
#68 Posted : 01 October 2015 22:50:44
That's a very nice looking engine BigGrin lovely work Cool
bugsec
#69 Posted : 03 October 2015 00:43:19
Thanks Dave it's pretty heavy too BigGrin
bugsec
#70 Posted : 24 January 2016 21:17:13
Pack 14 contains Stages 45 - 47.
Stage 45 - The gearshift pedal.
Parts supplied: Transmission case cover, Gearshift pedal cover, Gearshift pedal, Gearshift actuator and screws.
Also required: Grease (Stage 6).
bugsec
#71 Posted : 24 January 2016 21:18:15
Stage 46 - The kick-starter.
Parts supplied: Kick-starter arm and screws
Not much to do at this stage just tap the hole in the kick-start joint.
bugsec
#72 Posted : 24 January 2016 21:19:28
Stage 47 - The clutch cover.
Parts supplied: Clutch cover, Clutch cam lifter, Kick starter spring, Cable A, Cable B and screws.
Also required: Engine (Stage 44) and Kick-starter arm (Stage 46).
#73 Posted : 24 January 2016 21:19:37
That is looking really good, do love the shiny stuff!!BigGrin
bugsec
#74 Posted : 24 January 2016 21:21:14
Thanks Nem - not a patch on your Busa build though !!
bugsec
#75 Posted : 24 January 2016 21:23:06
Pack 15 containes Stages 48 - 50.
Stage 48 - The fuel cock and tank base.
Parts supplied: Fuel tank base (right), Fuel cock A, Fuel cock B, Rear brake spindle, Switch box, Fule cock tube A, Fuel cock tube B, Washers and Screws.
Also required: Right frame half (Stage 36).
bugsec
#76 Posted : 24 January 2016 21:25:51
Stage 49 - The left frame half.
Parts supplied: Left frame half, screws and washers.
Also required: Carburettor (Stage 17), Air filter case (Stage 25), Centre stand (Stage 37), Engine (Stage 47), Right frame half (Stage 48), Fuel cock A (Stage 48), Fuel cock B (Stage 48) and screws (Stage 48).
bugsec
#77 Posted : 24 January 2016 21:27:20
Stage 50 - The horn.
Parts supplied: Horn, Rear left indicator and screws.
Also required: Main frame (Stage 49).
bugsec
#78 Posted : 24 January 2016 21:28:17
Pack 16 contains Stages 51 - 53
Stage 51 - The left fuel tank base.
Parts supplied: Fuel tank base (left), Igniton switch, Ignition key, screws and washers.
Also required: Left frame half (Stage 50)
#79 Posted : 24 January 2016 21:29:29
Hmmm really tempted to go for this once the Busa is done, really nice build!BigGrin BigGrin
bugsec
#80 Posted : 24 January 2016 21:30:27
Stage 52 - The engine cables.
Parts supplied: Battery box, Cable A, Cable B, Joint A, Joint E, Base frame 1, Connecting Pin and screws.
Also required: Right frame half (Stage 50)
All the base parts were missing but as I have decide to keep the base packs unopened until all parts received and then build this is not a major issue.
Tomick has advised that the missing parts will be supplied at a later date.
8 Pages «<23456>»
This page was generated in 0.651 seconds.
