3 Pages 123>
perfecting the barrel Options
#1 Posted : 19 September 2010 16:57:39
I am sure I am not alone in thinking the barrels supplied in the kit are a bit lack luster! I decided to add a little detail!!
1. I started by sanding the barrel, not totally smooth but smoother leaving the grooves a lot shallower.
2. next I milled out the two ends to create a lip around the edge
3. Then I marked out the individual planks of the barrel with a pencil. once done I scribed over the pencil lines with a sharp blade
4. I gave the barrel a coat of thinned Humbrol light earth and left to dry
5. Once dry I began to ad the steel bands. i used strips of photo-etch, securing the end onto the barrel with supper glue than gradually fixing the band around the barrel (repeat 4 times!!)ensuring all the joints are at the same point on the barrel as these will be faced down once on the skids.
6. Once done I gave the whole barrel a was of thinned raw umber. this darkens the base colour and settles into the scribed lines adding definition.
Jack Sparrow
#2 Posted : 19 September 2010 17:03:18
Excellent bit of modification Jase. Very nice finish!!!Drool BigGrin BigGrin
Zeptrader
#3 Posted : 19 September 2010 17:09:42
I think that's just ridiculously brilliant, perfect, simple as that, well done that man, I'll bung my barrels in the post in the morning to ya! BigGrin
#4 Posted : 19 September 2010 17:20:56
Very nice Jase..let's face it...now they, look like barrels...er...where's the bung????
LOL LOL LOL
Jack Sparrow
#5 Posted : 19 September 2010 17:26:53
LOL LOL LOL
There is always one!!!!Flapper Flapper LOL LOL LOL LOL
willie
#6 Posted : 19 September 2010 17:33:20
that photo showed a empty barrel on board ships when a barrel was empty the metal rings were knock off the barrel was flatten to conserve space the were known as the first flat pack ,rings were never pined to the barrel
#7 Posted : 19 September 2010 17:34:09
simple as that took nearly 2 and a half hours Mellow
as for the bung i thought about a spot of green stuff but could not be bothered guess im getting lazy in my old age BigGrin BigGrin
benny
#8 Posted : 19 September 2010 17:41:19
good stuff jase well impressed
cheers benny
axle396
#9 Posted : 19 September 2010 18:34:44
Spot on Jason. I'm well impressed/jealousBigGrin
Jimmy L.
Revell USS Kearsarge
Titanic Lifeboat
piot007
#10 Posted : 19 September 2010 19:38:45
Very well done mate.BigGrin
I'll 'attempt' that, if ya dont mind.Flapper
Mr.Quist
#11 Posted : 19 September 2010 20:32:11
Hi Jase, Your improvements look very impressive. ThumpUp
Could you be so kind and explain this a little more.
I have no idea what this material is, I just
entered the model-ship world.
Regards, Mr.Quist
My build diary here
HMS Victory
#12 Posted : 19 September 2010 22:23:09
Photo etch is a thin metal usually brass. Photo Etch is comes as a sheet of parts used to up grade or add tiny detail to model kits usually plastic kits which is my background. the strips i have used are bits of scrap from a Panther tank. if you don't have photo etch you could buy thin plastic sheet and cut strips off or use the tape method described in the magazine, my only concern with the tape is that the adhesive may fail over the years and come undone?
Mike Turpin
#13 Posted : 20 September 2010 00:08:27
You can also use some 160 g/m2 stiff card, paint it with dull or matt black paint and then cut strips. Gives a good metal band effect.
Mike T
willz
#14 Posted : 20 September 2010 00:15:37
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Your barrels are superb, my problem is are they really 5ft tall, mabee mike t knows
#15 Posted : 20 September 2010 09:06:44
Excellent work Jase!
Mike Turpin
#16 Posted : 20 September 2010 10:15:27
Hi Willz
Strangely enough, the only size information I can find on the web refers to the capacity of barrels in gallons. When I humped beer around in a pub we had firkins which hold 9 gallons i.e. 72 pints. The largest barrel size is the Tun which holds 216 gallons. Assuming a firkin is about 20" long, (Just a guess based on memory, could be slightly more) in order to increase a volume by 24 times each linear dimension needs to be increased by a factor of approx 2.9, therefore the length of the Tun would be about 58" and therefore as it happens about 5'!
So to be strictly correct, the barrels are not barrels but Tuns and would hold 216 gallons. Normally they wouldn't be seen other than in the hold where they were laid on top of the shingle ballast which in turn was laid over iron or lead bars.
Raising them from the hold to re-fill was a major exercise.
BTW I think your Tuns are tons better than the original finish!BigGrin
Mike T
#17 Posted : 20 September 2010 10:34:30
Hi Mike, perhaps you might be able to shed some light on this one about barrels (old barrels) I remember seeing somewhere where the iron hoops were replaced by what looked like willow bands?? I would like your input on this one mate, thanks...
Confused
Mike Turpin
#18 Posted : 20 September 2010 11:12:40
Confused
I cannot find a direct reference to willow bands but seem to recollect what you are thinking about. It may be the difference between 'tight coopering' and 'slack coopering'. Tight coopering is making barrels to hold liquids such as beer, water etc and used the iron bands to pull the staves really tight by heating them (the bands) and allowing them to contract round the staves. Slack coopers made barrels for storing solid goods such as flour, cheeses, dried peas etc. Perhaps where a supply of iron was limited, wooden bands probably made of willow, because of its flexibility, would have been used instead?
All this is just conjecture, any information from a cooper would be welcome!!
Mike T
Paul
#19 Posted : 20 September 2010 11:20:13
Hi all, I think Mike may be correct with the willow bands because of the possibility of sparks in the hold which also stored gunpowder. If I recall correctly copper nails would also have been used. Kick my backside if I'm wrong Mike.
Also I found the 1mm tape on Ebay for £1.90 + £1 P&P.
Quintin
#20 Posted : 20 September 2010 11:36:03
I'm digging your barrels. Mine will have to follow in their footsteps.
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
3 Pages 123>
This page was generated in 0.093 seconds.
