2 Pages <12
Plank/Strake Thickness !! Options
Richard Bolitho
#21 Posted : 19 September 2010 19:37:44
Rank: Beginner Level 1
Thanks for the speedy reply shippers, looks like I'll be buying the electric bendersBigGrin
benny
#22 Posted : 19 September 2010 19:37:54
thomasmoult wrote:
Try my method; get a thermo flask, fill it with hot water boiled straight from the kettle, then drop the plank in. The hotter the water the better, and the plank need only be in there for less than a minute.
Take it out and immediately offer it up to the hull and bend it round the required bow area; it will bend, hold the shape and because the water is so hot, it dries before you can fix the pins in.
Works a treat for me, no need for plank benders etc just a trusty flask and a kettle!
Tom
i tried this today on the bow worked a treat and the super glue did dry instantly on wet planks
cheers benny
piot007
#23 Posted : 19 September 2010 21:43:07
LOL LOL Should av read this thread before asking you guys.
My questions are answered.LOL LOL
jeff averre
#24 Posted : 20 September 2010 00:40:09
Got a cheap 'Hair styling tongs' from Argos just over 3 quid, they work a treat!LOL
Jeff
Mike Turpin
#25 Posted : 20 September 2010 09:33:22
budgie wrote:
Hi Benny
Blushing poking my nose in here but am bit concerned bout u cutting of plug
UK is 240Volts most other European countries 120Volts (not sure bout Italy)
doesn't 2 pin to 3 pin travel adaptors reduce the 240V to 120V
concerned in case plankbender gets too hot & scorch ure planks or worse
I don't know where you got your information from but it is not correct!
See: Worldwide lookup table
Travel adaptors are simple devices which allow different pin-configurations to be used. Supply voltages have been standardised across Europe to within 10%.
Mike T
budgie
#26 Posted : 20 September 2010 11:31:34
Blushing Hi Mike thanks for ure correction
Blushing ordering eleccy parts in my job we have to ensure correct part # for country
Apoligies for any confusion
Bored mutterin to self "mind ure own business Budgie butt outCrying
RussG
#27 Posted : 20 September 2010 22:35:33
Thanks for all your replies, bending them aint going to be a problem, Soldering Iron with a roller on the end! (cheaper than a lecky plank bender). Time to start sanding the ribs down to get the shape right, so catch you all later.
Happy Building, Russ
#28 Posted : 20 September 2010 23:25:08
For those with electric plank benders you can buy a euro plug adapter from maplins that screws over 2 pin plug and converts it to gb three pin.
secretreeve
#29 Posted : 21 September 2010 07:45:43
lol dont do what my old man did with fridge/freezer several years ago.
he took the plug off it, put the wires in the socket and added another plug into the socket ontop of the wires.
when i had to unplug it was really confused and got shock lol.
and that was from a "qualified electritian"! im a better lecky than him and havent had any training! would NEVER do anything as stupid as that.
instead i just add the correct extension socket cable lol
piot007
#30 Posted : 21 September 2010 09:22:27
Years ago it was not mandatory to sell elec items with a plug top on them.
It is now.
I was 5 and got a globe with lamp in it for xmas, no plug top. No-one up at 5am but me(xmas day). I climbed behind the settee and unplugged the xmas dec lights and proceeded to wind the tail ends of the globe's lead to the pins on the plug top. Then i plugged it in. Thinking i was well smart.
BANG.
Everything went off. The plug top melted and 'arc-ed' out to the settee, setting it on fire.
My dad thanked the smoke alarm, for saving Xmas. Talk about chastise. My back side is still sore.LOL LOL Got 2 belts that day!LOL
Now im a spark myself. My family wont ever let me forget. BigGrin
RussG
#31 Posted : 21 September 2010 14:07:45
Cant see what all the fuss is about adaptors, cut the euro plug off and fit a BS 3 pin english one, so your left with two wires! Red or brown to live pin and blue or black to neutral pin. Leave earth pin in situ. Put in a fuse to suit (look at old plug for size, I should think 3amp).
DISCLAIMER: UNPLUG IT FROM THE WALL FIRST! IF IN DOUBT CONTACT, A QUALYFIED ELECTRICIAN WHO LIKE MYSELF WILL HAVE NO QUARMS ABOUT CHARGING YOU A £## CALL OUT FEE FOR THE PLEASURE. I TAKE NO RESPONSABILTY IF YOU DO THIS. Thanks for looking!
secretreeve
#32 Posted : 22 September 2010 13:33:00
problem is though, and this is NOT directed at anyone on this forum, just lifes simple facts, there are people in this world who despite it being moulded onto most plugs and printed on the plugs card, fail to know which pin is live, earth, nuetral.
and there are those who will turn the plug over read to put the wire in the left pin, turn it over (so the left pin becomes the right) and still puts it into the left (but which was right) pin.
it is because of this fact and people being killed becaused of it all uk appliances MUST now come fitted with a plug.
please remember thats NOT AIEMD AT ANYONE HERE>
Son of Bulwark
#33 Posted : 22 September 2010 13:59:09
Hi Shipmates! BigGrin Wiring a British 3 pin plug.
The Live(Brown) wire always has the fuse connected to it's pin, Neutral wire (Blue) is on the opposite side of the plug and the Earth wire (Green & Yellow) on the long pin at the top. If you don't have a 3rd wire, don't worry! the item doesn't need it!.
Simple rhyme from my school day :-
Brown is Live, Blue is Not, Green and Yellow Earths the Lot.
Darron
daffy09
#34 Posted : 22 September 2010 14:24:03
Hi Shipmates
I loved the 'Mr. Bean' episode, where he had just bought a new television and after a moments musing he proceeded to push the wires into the plug through the entry hole at the bottom. Just from memory, I believe the tv worked.
Know this was a comedy sketch, but this is something that really SHOULD NOT, NEVER, NO WAY, be attempted at home.
Happy building
Daffy09
RussG
#35 Posted : 22 September 2010 22:20:11
Darron
Hi Darron I remember that rhyme as well, The only thing is that untill someone has actually done it, then end up looking at Red & Black Wires!(Red is L Black is N)the rhyme wont work! lol
Moulded plugs were introduced only becuase of trading standards look here to read all about it http://en.wikipedia.org/wiki/BS_1363
Quote:
secretreeve: it is because of this fact and people being killed becaused of it all uk appliances MUST now come fitted with a plug.
Sorry your wrong an appliance does not have to have a plug fitted if it is intended to be fixed ie cooker, fridge, heaters etc. And you can still buy lamps etc from major retailers where a normal white non moulded plug is fitted.
One eye
#36 Posted : 22 September 2010 23:32:07
Hi guys.
In the past, I have soaked planks in tap water over 2 hours (the water cools anyway), sometimes longer; in an upright Spagehetti glass - about 2 foot tall. The supplied planks I used doing HMS Victory, Constructo - 1/92 model, were Hardwood not soft, 2mm thick and ba****ds to champher, but easy to bend under the right conditions. I found the right conditions to be:
1. Plenty of soaking.
2. Plenty of heat.
3. Plenty of wrist action!!OhMyGod Unsure
Back to bending planks! A flat headed soldering iron was perfect. You dont need a round headed expensive 'Plank bender', or a fancy curved Henry Moore sculpture to do it on. A soft piece of wood, a movable heat source, a hard surface to resist the next bit; a wrist which will either move the heat around and over the nice soft plank, or a nice soft plank which you can move over a heat source (the way it was done many years ago when they built the real things).
The soldering Iron was ideal when dealing with bends which where not on one plane. I will try and dig out some old photo's to give an idea, but tend to think that the likes of Karl and Mike T may have some to hand.
Either way Lad's, enjoy your new found hobby of bendingConfused Confused
See Ya.
2 Pages <12
This page was generated in 1.654 seconds.
