27 Pages «<678910>»
Garth's Build Options
Gerrit
#141 Posted : 05 October 2015 09:09:56
Hi Garth
Really coming along nicely
Keep up the good work
Gerrit
Garth
#142 Posted : 05 October 2015 12:28:06
Hi Gerrit.
Thank you for looking in and for the kind words.
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Garth
#143 Posted : 06 October 2015 12:26:29
Hi All,
Been working on the Catharpins and Futtock shrouds this past weekend. All went fairly well according to the instructions. Once again my Hackle pliers were pressed into service. It was much quicker using them to temporarily hold the Futtock shroud in place rather than tying them with scrap cotton as the instructions suggest.
I must admit that I was a little disappointed with the result – the knots ended up being a little too bold. I must get used to trusting a single half hitch and white glue knot. Having sat back and looked at it again I’ve decided to leave them as they are. I hope that once all the spars and sails are fitted they will become less obtrusive.
Well, that’s it for issue 95. DONE!!! 18 hours total, which makes this my longest issue to date.
Kind regards,
Garth
Garth attached the following image(s):
#144 Posted : 06 October 2015 23:53:38
A real neat and tidy job on those futtocks Garth, you patience certainly has been rewarded....Drool Drool .. Very well done....
Garth
#145 Posted : 07 October 2015 06:46:26
Hi Alan,
Thank you for looking in and for the inspirational comments.
Kind regards,
Garth
#146 Posted : 07 October 2015 08:38:44
BigGrin Lovely job looking very nice Cool
#147 Posted : 07 October 2015 12:48:29
Excellent job there Garth. Patience does pay off. well done
Garth
#148 Posted : 12 October 2015 15:48:17
Hi Martyn and Hans,
Thanks for looking in. It's amazing that when you get to building, the hours simply fly past. Looking back I sometimes think "How is it possible that this took so many hours?"
Any way, I suppose its the journey and not so much the destination. Well in my case it is. (As you can see from all my half finished models)Blushing
Kind regards,
Garth
Garth
#149 Posted : 13 October 2015 15:27:04
Hi All,
Completed the upper shrouds. Everything went pretty well. Except that I must have forgotten to shrink one of the Deadeye binding heat shrinks.Cursing
As I pulled the cotton through the Deadeye, the whole assembly came apart in my hand. Fortunately I was able to bind it again. I tacked it together with white glue and once it had dried I redid the binding. I did not use the heat shrink again, and to compensate for the difference in thickness, I wrapped a second binding over the first. All’s well that ends well!!!
I’m really glad that this part is complete, it felt like it was never going to end.
#150 Posted : 19 October 2015 09:50:27
Good job Garth, good job. These things are sent to try us but succeed we will.
Garth
#151 Posted : 21 October 2015 12:59:49
Hi Hans,
You are so right.
Kind regards,
Garth
#152 Posted : 21 October 2015 13:22:58
Turned out very nice indeed Garth, now you have the even more exciting job of doing the ratlines, am sure you'll enjoy that just as much as you did the shrouds....Cool Cool Cool .. All part of putting this beautiful ship together and you're doing a great job of it too....Cool Cool .. Look forward to your next update.
#153 Posted : 21 October 2015 21:17:55
BigGrin looking great and nice workCool
Garth
#154 Posted : 22 October 2015 11:22:06
Hi Alan and Andy,
Thank yo for looking in and for the kind comments.
I am gently glancing the ratline instructions, looks like I'm in for another marathon.
kind regards,
Garth
#155 Posted : 22 October 2015 11:33:06
BigGrin Hi Garth the ratlines are a real marathon as I found out on the SoTs but if you do a little but often its very satisfing getting to the end Cool but Iam sure you will make a cracking job of itThumpUp
#156 Posted : 22 October 2015 15:04:25
Never mind Garth, you are quite capable of doing it, after the shrouds.
#157 Posted : 22 October 2015 15:35:51
Garth
#158 Posted : 23 October 2015 08:42:58
Hi Martyn, Hans & Steve,
Thanks for the inspiration. Actually quite looking forward to it.
Kind regards,
Garth
Garth
#159 Posted : 23 October 2015 12:20:18
Hi All,
A small addition today.
I found it difficult to hold the heart block thread and then bind them. (As the instructions indicated that we would)
To overcome this, I secured the heart block with a half hitch, glued it and waited for it to dry. I then used my Hackle pliers rigged with a counter weight over the fighting top. A 520gr Martini Henry bullet worked a treat.
This arrangement maintained the tension on the heart block and I was able to bind it quite easily. Next will be to rig the stays.
I’m really looking forward to this!!!
Garth
#160 Posted : 21 November 2015 07:33:03
Hi All,
Fitted the Lower mast stays. I had some problems lashing cotton between the stays. The cotton provided seems to be nylon and the knots kept on undoing themselves.
Unfortunately my time has run out, I think I’ll use the 0.25mm cotton instead.
Kind regards
Garth
27 Pages «<678910>»
This page was generated in 0.306 seconds.
