glue Options
max001
#1 Posted : 18 October 2015 04:42:18
I see a glimpse of the tube of glue in the build, any chance Mr T you could show photo of it so I can show it to our Loctite rep regards max001.
#2 Posted : 18 October 2015 12:26:46
In respect of gluing what?
The wooden content is glued with Aliphatic resin wood glue, the diecast metal and platic elements are glue with a fast set epoxy and Loctite superglue gel
max001
#3 Posted : 18 October 2015 17:21:43
for glueing the plates,the best I have got hold of is Loctite super glue power flex $6.00 a small amount, I get about two and a half leading edge plates its getting expensive.
#4 Posted : 18 October 2015 17:39:04
For the plates you could try EvoStik timebond, which is an adjustable contact adhesvive, available in 65g tubes and 250ml tins (which can also be used for the plates of the DC-3).
max001
#5 Posted : 20 October 2015 23:52:54
Thanks Mr T,tried bostik here in Australia never heard of it try bostik UK,
I did they informed me they cannot deliver as it highly inflammable so I will stick with Loctite, cheers max001.
This page was generated in 0.107 seconds.
