late revisions Options
jethro
#1 Posted : 18 October 2015 15:29:44
Can I ask some of you who are near or even finished your Red Bull builds what revisions we can expect from this kit. I've only just started on this and have come across two mistakes already with the bass plate on the front wing (needs removing after fitting and refitting) & now the front shocker leakes so extra bits need putting on that come in a future delivery.
I came across this type of thing in my last build and apart from possible damage caused is so frustrating
If they can't correct instructions then at least print a revision list so we know what to expect Angry Angry
Sorry if this upsets some people but you pay good money for these kits & if this is their stock in trade then????
jeff
rowdy85
#2 Posted : 20 October 2015 04:43:54
I did find having to remove parts of the display front wing to complete the next step a bit silly, and those tiny screws don't take too much effort to strip out the head on. If your shock is leaking from the bottom, you have have accidentally pulled the seal out. (two small rubber rings and a plastic clip that looks a bit like a spider) At a later stage the shocks will need to have spacers added as part of a revision. If you do end up pulling them apart maybe leave them apart untill the spacers arrive. Cool
#3 Posted : 20 October 2015 08:30:29
The instructions revisons are noted in my build, which is you are only just starting off, you can se the entire collection, what is done and when, and certainly the shock revison has been posted as a sticky
http://forum.model-space...spx?g=posts&t=11718
This page was generated in 0.093 seconds.
