11 Pages «<23456>»
Tigerace`s Akagi build Options
#61 Posted : 09 October 2015 14:42:32
It's really taking shape, looks like you are doing an amazing job with this!
Look forward to seeing more Cool
#62 Posted : 16 October 2015 11:36:51
cheer`s guy`s i`m now fine sanding the hull and added the deck`s BigGrin more to follow BigGrin
michael.rolph
#63 Posted : 16 October 2015 14:20:33
tigerace wrote:
hi all thankyou for your input,as anyone had problems with missing part`s with this build? as i`m missing some key parts in 16, 17 and18 have emailed deag but no response as yetConfused Cursing
Great work so far :)
I checked my parts and found I was missing the short planks from issue 17. Contacted customer support and they sent out a replacement pack 5, unfortunately the sent the pack 5 from the 12 month subscription so I got a pack containing issues 33-40 :( I'm still waiting for a response to my e-mail about it.
#64 Posted : 16 October 2015 18:32:28
BigGrin Hi Tigerace
Sorry to hear about the missing parts, sometimes phoning CS gets a quicker response than the e-mail route.
Looking good, I hope that you havent glued those lift boxes in place yet as instructed by the instructions,if you take a look here although Im sure you have already found it Yaturo gives some insights
http://forum.model-space...aspx?g=posts&t=4185
I am now in the position to finally finish my Akagi and will be continuing my diary shortly, although I have now opted for the sealed flight deck and it will have a proper wooden deck added.
#65 Posted : 16 October 2015 19:22:20
thanks Michael, sorry about your missing parts.but hopefully they`ll sort it for you like they did for meBigGrin
#66 Posted : 16 October 2015 19:26:47
Hi Andy thankyou and no i`ve not put the elevators in yet,just got pack 13 today so i`ll be adding all the components soonCool ,i always check out your build and what you did as your`s is nearly complete and i`ll look forward to seeing the end results of your buildBigGrin
#67 Posted : 16 October 2015 19:27:09
Looking good, keep them coming BigGrin Cool
#68 Posted : 17 October 2015 10:01:34
Looks like you're doing a great job, very neat and very clean.... Look forward to your next update....Cool Cool
#69 Posted : 18 October 2015 12:06:10
thanks everyone your comments are most welcome and very appreciated BigGrin
#70 Posted : 18 October 2015 12:07:16
here`s pack 13 Cool
#71 Posted : 18 October 2015 12:09:43
Has advised by Andy not to glue elevators until you get all the internal componentsBigGrin cheer`s phil
#72 Posted : 18 October 2015 13:07:30
BigGrin A plethora of parts there the smallest lift will need the parts adjusting so they all fit inside if I remember correctlyCool
#73 Posted : 19 October 2015 13:10:10
thank`s for the heads up on that one AndyBigGrin ,i think that`ll be in pack 14Confused
#74 Posted : 19 October 2015 14:04:51
Looks great Tiger. Your doing a grand job on her.
Chris
DaDokta
#75 Posted : 20 October 2015 09:27:05
Great build so far!
Will any of the detail of the lifts be seen on the final model?
As i understand it, there has to be some platform the lift is lifting (?) - which would cover all the parts at the bottom?
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#76 Posted : 20 October 2015 14:51:36
thanks Chris and thanks Walter has i`ve not received any of the decks etc i don`t no how i`ll display the lifts would be a shame not to show at least one of the lift`s internal detail thoughConfused
#77 Posted : 20 October 2015 21:56:09
BigGrin Hi Tigerace
Sorry to butt in and jump your diary but I can tell you about the lift machinery and how it can or cant be seen.
If the decks are left removable and the lifts are in line with the flight deck or mid deck then the machinery will be seen when you remove the flight decks and top inner deck parts. If the lifts are left at the very bottom or in line with the lowest deck then it will cover the machinery. hope this helps.
#78 Posted : 21 October 2015 16:09:55
cheer`s Andy will have a look when i get to that stageCool
#79 Posted : 25 October 2015 11:37:42
completed the bow lift very fiddely Cursing more to follow BigGrin
#80 Posted : 25 October 2015 11:59:43
Very nice... Fiddly work certainly tries the patience but your efforts have definitely paid off.... well done....Cool Cool
11 Pages «<23456>»
This page was generated in 0.429 seconds.
