wolfskin Options
wolfskin
#1 Posted : 26 October 2015 01:52:42
Rank: Beginner Level 1
I have managed to glue & Pin the Lower deck OK .However I had a bit of difficulty with driving the pins . I used a small nail punch and a tack hammer and eventually got them all in without bending,but it was not easy .Is there a better tool available for driving these Pins?
Cheers WolfskinConfused Confused
#2 Posted : 26 October 2015 07:29:55
Hi Wolfskin, personally I tend to predrill any pinholes, it makes the job a lot easier and the pins are not likely to bend so easily. I also use a small pair of long nose pliers to hold the pins and a small hammer, find it easier than using a pin pusher... Other modellers will have their own preferred methods of course.... Cool Cool
Hope this helps.
#3 Posted : 26 October 2015 07:43:41
BigGrin I totally agree with Alan on this one I have tried all types of methods and found that one is the best Cool
Looking forward to seeing your build Rgd Martyn
wolfskin
#4 Posted : 27 October 2015 06:28:37
BigGrin Thanks guys , I have already got a pin drill chuck and have had an experiment . works real good .
Many thanks BigGrin BigGrin
#5 Posted : 27 October 2015 12:26:35
Hi wolfskin...I agree with my fellow shipmates and am glad you were able to get sorted...I personally pre-drilled then inserted the nail into the hole making sure that it was straight then used a pin pusher and light hammer to drive the nail home...Good luck with your build. Will you be making a build diary??
Regards...Jonny
Smile ThumpUp
This page was generated in 0.107 seconds.
