mast holder Options
drake
#1 Posted : 21 September 2010 10:37:45
In issue 10 we were given a mast holder. No reference has been made to its insertion into the model. There is a gap in the keel which I think is it's home but now the lower and middle gun decks are in position, I can't fix it. Is this an ommission in the instructions? If so, any ideas on what I can now do?
willie
#2 Posted : 21 September 2010 11:35:48
its just for linning up the bottom of the mast port and stabouard realy needed if only one deck but with 2 or three decks the deck holes will line up the mast just cut it and fit it if you want to
#3 Posted : 21 September 2010 12:13:11
Not sure why we have the same question running across two topics, but if you refer to step 3 of issue 16, it tells you to locate all frames into the false keel, the mast support frame part 6) is shown in place at step 5 on page 12.
Cut the part in half top to bottom, then glue and insert the halves from either side underneath the lower gun deck.
Mac
#4 Posted : 21 September 2010 12:44:05
Thanks for the heads up on this matey I had completly forgotten about it. BigGrin
Pam's shipyard is closed for now no more room!
This page was generated in 0.310 seconds.
