Clamping the Sapele Planks? Options
Broven
#1 Posted : 31 October 2015 06:48:01
Hi folks,
So tomorrow I should be ready to start the second layer of planks. But it got me wondering... how do I hold these in place while the glue sets? I'm curious what methods you all use, as I'm struggling to think of a workable plan. Of course, it is almost 2am here, so maybe I'm just too tired to think clearly. lol
Thanks in advance for any suggestions.
Tim Johnson
I came here in peace, seeking gold and slaves. - Jack Handy
Builds: Sovereign of the Seas, Amati Chinese Pirate Junk
#2 Posted : 31 October 2015 08:08:39
BigGrin Hi Tim the planks for the second layer won't need holding in place as they are very thin and the glue holds them in place . For planking the bow I ran the planks through my fingers to get the right curve before glueing them down Cool
Hope this helps Rgd Martyn
#3 Posted : 31 October 2015 10:02:01
Hi Tim, to hold the second planking in place while the glue sets I used round headed map pins. Inserted the map pins close to the edge of the strip, being careful not to damage the edge and found the head of the pin held the strip in place..... Attached link shows it clearly.... Hope this helps....Cool Cool
http://forum.model-space...sts&t=5013&p=61
Broven
#4 Posted : 31 October 2015 15:36:17
Thank you for the replies. BigGrin I'm feeling a little more confident to begin this part now. I believe this will be the first bit of the ship that will remain visible on the final model, so a little nervous about getting it right. lol
Tim Johnson
AdamHall
#5 Posted : 31 October 2015 15:45:57
G'day Tim,
Another option for you to try out. I am using blue painter's tape cut into small strips (about 1.5 inches long, then cut the strip width way onto two). The blue tape has just enough adhesion to hold the planks in place. This I found was advantageous to ensure that the new laid strips butt up flush against the previous.
Take care though when peeling off the tape when finished to avoid removing any splinters from the sapele. I did not encounter this, but just in case. I found that I could use the strips twice and marked the re-used with an X so I could keep track of the new and used. I am currently planking the lower hull and provided a photo of my method.
Ciao,
Adam
AdamHall attached the following image(s):
Broven
#6 Posted : 31 October 2015 15:49:35
That's a great idea, Adam. I happen to have some painter's tape on hand. I'll give this a try. BigGrin
Tim Johnson
AdamHall
#7 Posted : 31 October 2015 16:01:54
Hi Tim,
No drama, different strokes for different folks. Suggest that you do a dummy run on some scrap just to be sure that the tape you use does not mess up your end result. I'm using Scotch 3M brand.
Ciao,
Adam
nightwisher
#8 Posted : 31 October 2015 21:01:36
Hello again Tim,I used this glue (see pic) to fix the second layer of planking,it grabs quicker than pva. I just put a thin layer on the plank and held in place with my fingers until it grabs then clean off any excess with a damp cloth before it dries.Good luck whichever method you use.
nightwisher attached the following image(s):
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
Broven
#9 Posted : 31 October 2015 21:16:16
I've heard great things about Titebond lately. I've been using Gorilla Glue, but I do believe I'll be switching to Titebond once this bottle is empty.
Tim Johnson
This page was generated in 0.667 seconds.
