11 Pages «<34567>»
Tigerace`s Akagi build Options
#81 Posted : 25 October 2015 20:16:01
BigGrin Nice work on the lift there a chalenge and sometimes a shoeCool horn comes in handy but thee results speak for themselves
#82 Posted : 26 October 2015 12:14:15
thank`s guys Cool
#83 Posted : 28 October 2015 20:26:52
I have noticed that some of the thin ply pieces are really warped Cursing
#84 Posted : 30 October 2015 12:22:47
i`ve deceided if i can`t straighten them i`m going to make new one`s from some strene sheetConfused
#85 Posted : 01 November 2015 21:27:40
Looking great. There is certainly a lot of work in those lifts.
#86 Posted : 01 November 2015 21:48:55
BigGrin Replacing the thin ply with styrene will work fine I think and should help stabealize everythingCool
#87 Posted : 05 November 2015 13:00:43
thank`s guy`s i`ve made the first warped piece 2 more to go Cool
#88 Posted : 05 November 2015 19:21:28
BigGrin Hi Tigerace
If I remember correctly that is the sloping part under the funnel, you mat need to jockey the parts a little but they all fit with some fetling. Looking good .
#89 Posted : 07 November 2015 13:09:47
Thanks andy for your commentsBigGrin also i found your enhancements to the props on an earlier page in your build diary LOL
#90 Posted : 08 November 2015 15:46:07
well gave the hull it`s first coats of primer today will post some picture`s when it`s dry Cool
#91 Posted : 08 November 2015 19:53:09
here`s first photo`s going to sand back and fill ant mark`s or blemishes then further coats Cool thanks
#92 Posted : 08 November 2015 20:30:48
BigGrin Looks great, I remember turning mine into a banana tooLOL. If your using the Halfords Primer filler leave it for a good 2/3 days so it fully cures before sanding it back. One nice thing is it changes colour as you sand the darker yellow being the unsanded part.Cool
#93 Posted : 09 November 2015 15:01:57
will do that AndyBigGrin thanks for looking inCool
#94 Posted : 11 November 2015 19:26:44
thanks Andy took your advice and waited 2 days to sand back fill the blemishes and little bits i missed will spray again tomorrow,also do you no why we have to draw a line 1mm on the metal strip on page 186 cos it looks like you have to bend it then file it can you remember on your build please ?Confused cheer`s phil
#95 Posted : 11 November 2015 19:47:11
BigGrin Hi Phil
The metal strip is marked so you can get the bend exactly right, best to use a vice or etch bender tool with rubber protectors and a square of something hard to bend it, using this method there will be no need to score the back with a file and keeps the part stronger.
The reason being if you bend it around a ruler the windows can distort towards the centre side strip as there is little support here. Slightly over bend it as its easyer to pull back than push forward if you see what I mean.
Also to make things easyer for yourself paint the section behind the windows Matt Black as it saves trying to do it later like I did through the windows.
#96 Posted : 11 November 2015 21:15:29
cheer`s Andy thanks for explaining that as the instructions are a bit vageConfused
#97 Posted : 13 November 2015 18:57:21
Hi all pack 14 arrived today so will be able to build up the final lift also painted the other two BigGrin all comments welcome cheer`s philCool
#98 Posted : 13 November 2015 23:33:52
Looking good Phil, well done.....Cool Cool
#99 Posted : 15 November 2015 14:23:24
Thanks AlanCool Building the final lift Andy is right about this one you`ve got to move the bits around to get them to fit correctly Cursing
#100 Posted : 16 November 2015 13:37:08
Here`s picture`s of the final lift and the other two also added the bilge keel`s cheer`s PHIL
11 Pages «<34567>»
This page was generated in 0.225 seconds.
