3 Pages <123>
Richard's Trumpeter SA-8 'Gecko' Build Diary Options
#21 Posted : 23 November 2015 19:34:40
BigGrin Looking greatCool
richmal
#22 Posted : 27 November 2015 14:43:07
Rank: Amateur Level 1
Thanks for the comments so far. This build will take a little time since my work involves night shifts and I don't get to spend as much time at the workbench as I would like. Moving on........When attaching the suspension units to the hull I first attached the central axle stubs with masking liquid (Humbrols Maskol) These pieces will need a little movement when placing the suspension units over them. Secondly you will probably have to open up (I had to) the lower square recesses on the hull slightly to allow the suspension unit square lugs to fit in.
The suspension is almost complete. Undercoated and painted with A.Mig-931 Russian Dark Base which I use for most of my Russian builds. Apart from the 2 centre wheels, which are rigid, I have left the remaining 4 off along with the steering arms which I will cement in place once I have decided on the angle of steering that I want to create.
The photo shows the amount of steerage available, the hull/suspension steering linkage arms and the linkages themselves.
Photos of 'Gecko' with wheels turned are hard to come by but I did find some accurate CAD drawings showing them off very well.
richmal attached the following image(s):
#23 Posted : 27 November 2015 21:32:23
You are doing a great job.
That looks a really good kit and what a look to it - those old Russian design are so odd looking but appealing.
Many years ago I was into photography - started in a camera shop and did all of my own developing.
First enlarger I ever bought was made by Zenith (how many remember their old 35mm camera's?)
It was basic and ugly but bearing in mind its the lens that counts it was great. Lot to be said for it.
And when you start to look at 60's and 70's East European military it does just that without all the western frills and curves of some the things they have put out.
Keep up the good work as its a really interesting build.
richmal
#24 Posted : 28 November 2015 11:14:16
Thanks Birdaj2.
It's the ugly but mean look I like about Soviet/WP vehicles of the 60/70s. As you say they have a certain appeal to them which more modern vehicles don't have for me. On British armour I don't model anything later than Chieftain which still had sufficient angles & external additions to make it interesting to the eye. Once they started putting reactive armour over everything it all started to look similar.
Apart from that, I was a 60s - 80s Cold War Tankie and was starved of all the new(ish) cold war armour at the time.
#25 Posted : 28 November 2015 13:27:25
Fantastic work on this so far Richard and the internal lighting looks very cool. So nice to have someone on here who is a big fan of military modelling - it is much appreciated and will always get my interest.
Well done on a very cool build Richard, looking forward to seeing more - keep it coming!! Cool Cool ThumpUp
P.S. - This reminds me that I must get some more done to my 1:35 Tamiya 'Matilda' build soon?! ThumpUp
richmal
#26 Posted : 29 November 2015 21:28:00
Next on the to do list is the Drivers/Commanders cab. The instrument panel has been hand painted with the dials cut from the larger kit panel decals.
A mixture of Humbrol enamels were mixed to make up the bulkhead colour although I think it should be a more sickly green colour. The remainder was painted in acrylics.
#27 Posted : 29 November 2015 22:49:39
Stunning work with the dials ThumpUp
#28 Posted : 30 November 2015 00:27:57
Impressive work, looking great....Cool Cool
richmal
#29 Posted : 05 December 2015 23:30:10
I'm presuming that I did not post this next pic since it doesn't show up in previous posts.
It's the view of the drivers/commanders csbin with the instrument panel and steering wheel in position.
richmal
#30 Posted : 05 December 2015 23:41:58
There are a few internal upper hull details that need to be addded but these are straight forward and few in number.
I'm not sure what parts E26 to E28 (sub assembly [J-J]) represent but since I intend to fit it with it's external door (E1) open I cemented parts E26 & E27 together. Spray painted the interior and backplate E28 separately. If this is attempted after installation it will be difficult to get the paint coverage inside the unit.
richmal
#31 Posted : 05 December 2015 23:53:11
Having completed the painting of the lower and upper hull interiors it was time to move on to the upper hull exterior.
This part of the construction is very straight forward with a few pieces of PE to add two of which are handles that require a bit of bending.
I haven't added all the external parts since some of them will need a base coat on both sides, get in the way of future painting or be easier to paint as individual items. The photo below shows those parts.
richmal
#32 Posted : 06 December 2015 00:14:15
During this week I have been toying around with the upper radar array. The kit does not allow the radar dish to rotate and therefore if assembled as the instructions show the radar dish will be permanently fixed facing the rear. I wanted to be able to position the radar in whatever position I felt showed it off to it's best.
On viewing videos on U-Tube and googling the 'Gecko' I found that kit parts C86 & C87 are not fitted to working radar arrays. They are probably locking bars to hold the array whilst traveling inactive.
Internet browsing also showed the point of where the rotating head is attached to the fixed base. This area is on parts A11 & E9 once cemented together. Having found this point, using a thin razor saw, I carefully separated the pieces on the line as shown in the photo. i Added a thin shim of plastic card to replace the cut away portion of the rotating base. Now it was just a matter of drilling a hole from the top of the mounting, through the shim and on through the top of the fixed base and adding an appropriate length of plastic rod.
Here's hoping the pictures will show the process.
#33 Posted : 06 December 2015 11:40:33
Looking good Rich, excellent work....Cool Cool
#34 Posted : 06 December 2015 18:04:55
richmal
#35 Posted : 06 December 2015 18:22:09
After a suggestion posted to HAD Models and a flurry of e-mails later it looks like they will produce improved Missile Bins for the SA-8 'Gecko' in the near future. Their missiles for the Trumpeter SA-6 and missile bins for the Skif SA-13 did a lot to improve those particular models.
richmal
#36 Posted : 13 December 2015 21:44:50
Moving along, I have now completed the work and undercoated the Radar Dish. Although, the mounting is designed to elevate & depress I have cemented it in the upright, roughly horizontal, position. This allows me to add a few wires to the rear of the mounting. This does not affect the dish rotation. The following photos show both the completed Radar Dish/mount, with a note as to where I added the extra wiring, and the remainder of the Missile launch platform.
Instead of following the kit instructions I added the outer radar array mounting pins to the inner plate rather than the outer. Here I found another error in the instructions. Radar Mounting Pin, parts D50 (x 2) and D52 (x 2) need to be swapped over with D50s on the outer edge and D52s o the inside.
Care needs to be taken when constructing the Missile Box carriers. Wherever possible leave cementing as much as possible until the whole unit can be attached to the launch platform. This will allow you to get the boxes lying horizontally. Once happy with the fit and angles cement it all in place.
richmal
#37 Posted : 13 December 2015 22:18:03
Having dealt with the building of the Missile Launch Platform it's now back to both the hull and platform. The parts of the model that I have left off the model for ease of painting have now been undercoated and the upper hull cemented to the lower hull.
Almost the final job for today was to give the whole kit a layer of base coat. In this instance I have used A.MIG-931 Russian Dark Base.
richmal
#38 Posted : 13 December 2015 22:30:07
Last on the list for today was to give the front radar arrays a coat of the peculiar tan/brown colour on the inside surface. Following the photos from http://www.dishmodels.ru/wshow.htm?p=1080 which appears to be an in-service 'Gecko' I mixed paints in the following ratio.
Vallejo Model Colour 70875 Beige Brown - 10
Vallejo Model Colur 70.911Light Orange - 15
A.MIG-047 Satin White - 5
This gave me the approximate colour of the radar array as can be seen in the photo within a photo. I do understand that copying colours from a photo can give a false colour but it matches with other photos from elsewhere.
More to come next weekend.
#39 Posted : 13 December 2015 23:22:53
Very nice attention to detail and that etched radar looks brilliant
#40 Posted : 14 December 2015 00:39:25
BigGrin Now thats starting to come together nicely with some stirling work to get it to this standard, nicely doneCool
3 Pages <123>
This page was generated in 0.573 seconds.
