nose mounting plate. Issue 73 Options
Steve279021
#1 Posted : 08 December 2015 22:31:23
When gluing the nose mounting plate to the front of the monocoque it says that you should put glue only on the top of the monocoque and not all the way round the sides. Why is this?
Dodge charger build complete
Warthog
#2 Posted : 09 December 2015 09:49:27
Hi Steve
I'm guessing so that it limits any glue possibly oozing out to the edges and on to the paint work plus the lower body panel will hold it in to place as you can see by the 2 recesses on the end plate.
Spencer
Steve279021
#3 Posted : 09 December 2015 10:45:51
ok, cheers SpencerBigGrin
This page was generated in 0.097 seconds.
