3 Pages 123>
Malc's (yes ! another Mclaren ) M8 Options
RM1
#1 Posted : 12 December 2015 14:50:43
So, while patiently waiting for my Senna 4/4 packs I thought I should keep busy with something a little different. It is a Mclaren but the car where it all started, a CanAm M8.
RM1
#2 Posted : 12 December 2015 14:53:44
The kit is a little disappointing in terms of detail and moulding quality. I thought this would be a pretty straight forward build but I'm already planning wiring and plumbing BigGrin There are no plug leads or fuel lines ( not even a fuel pump !!Confused ). Looks like this was originally a battery powered model.
Malc.
#3 Posted : 12 December 2015 19:54:48
BigGrin Something different though and looks a nice kitCool
#4 Posted : 12 December 2015 21:36:24
Hello Malc,
I do vaguely recall seeing this kit in a model shop in the mid '70s and I'm sure it was one of those daft motorised models back then? Probably the same mouldings from that old kit minus the electrical bits, but no reason why it can't be made into a nicely detailed model and with your recent history of scratchbuilding some nice details on your models, I'm sure you'll make a fine job of it - even if you were hoping to not have to do it yourself?! Cool ThumpUp
'Accurate Miniatures' did a 1:24 scale Mclaren M8 in several variants (A, B & I think a C as well?) which was very highly detailed as a standard kit and which builds into a super looking model with patience as it's not the easiest to build, though it's getting harder to find one nowadays that isn't silly money?
'Zero Paints' sell the 99.9% accurate 'Can-Am Mclaren Orange' for this model, you can find it here:
http://www.zero-paints.c...60ml--product--109.html
Look forward to seeing how you get on with this build Malc, I'm sure it'll be very cool when completed my friend?! Cool Cool Cool Cool ThumpUp
RM1
#5 Posted : 17 December 2015 05:08:26
Hi Kev,
Thanks for the info on the paint. Zero paints are not distributed (as far as I can tell) in SA and they won't ship dangerous goods in small quantities. I'll keep trying to find it but may have to stick with the Tamiya orange.
Malc.
RM1
#6 Posted : 19 December 2015 14:27:11
I've made a bit of a start on the V8 block.
RM1
#7 Posted : 19 December 2015 14:31:12
The body panels are showing quite a lot of "sink marks" so I'm putting some efforts into filling and smoothing out.
RM1
#8 Posted : 19 December 2015 14:32:02
RM1
#9 Posted : 19 December 2015 14:35:56
The engine is quite lacking in detail so I'm going to add plug leads and fuel lines ( and a fuel pump ! ).
The distinctive inlet trumpets have these spikes which I will drill 0,8 and add a connector of sorts. Something like this.
RM1
#10 Posted : 22 December 2015 15:38:18
The engine's taking shape. Used alclad2 on the inlet trumpets and trying some different wire sizes for the plug leads and fuel lines.
RM1
#11 Posted : 22 December 2015 15:42:19
From the few pictures of the M8A that I can find it seems like the fuel pump could be a mechanism at the rear end of the head between the cylinders. I found a left over cylindrical part from another kit and added some connectors for the fuel lines.Maybe not to accurate but should do the job.Cool
#12 Posted : 22 December 2015 19:24:16
Very nice work Malc Love Love That Alclad certainly gives a fantastic finish Drool
RM1
#13 Posted : 24 December 2015 14:03:31
Thanks Dave, yes that paint is great. ( stretches my limited airbrush skills though BigGrin )
Malc.
#14 Posted : 24 December 2015 16:28:39
Lovely work so far Malc and that scratchbuilt fuel pump looks perfectly acceptable to me my friend!! Cool ThumpUp
Watching your build with interest as always. Cool
RM1
#15 Posted : 29 December 2015 16:19:34
Some progress with the wiring and general engine stuff.BigGrin
RM1
#16 Posted : 29 December 2015 16:24:17
The suspension on this model ( well actually there isn't any ! Confused ) leaves a lot to be desired. I guess it's because it was intended to be a battery driven toy.
It would actually make a good subject for a scratch build project to get some detail under the hood. BigGrin
It looks like the belt drives were running right behind the drivers head. No pony tails in those days Cool
RM1
#17 Posted : 29 December 2015 16:29:25
A quick check that the bodywork still fits.
RM1
#18 Posted : 31 January 2016 13:29:44
Quick update. Not had much time for the models in the last couple of weeks.
I used a Alclad2 polished Aluminium for the tub.
I deleted the previous post as i wanted to change the pictures but couldn't find a way to do it?
RM1
#19 Posted : 31 January 2016 13:31:59
Alclad2 Chrome for the wheels and roll hoop.
RM1
#20 Posted : 06 February 2016 15:11:20
Although this is not a model for details, I've added a few hoses and cables just for practice BigGrin
3 Pages 123>
This page was generated in 0.837 seconds.
