 Rank: Pro  Groups: Registered
Joined: 30/03/2010 Posts: 143 Points: 434 Location: cheshire
I'm not going to put a step by step of my build on here as i think most people have now got to the point of planking so IL start with all the ribs in place and lower gun deck painted I'm going to paint it the only difference I'm going to double plank mine if I'm not satisfied with my planking we'll just have to see    now to the bow section Ive made a start on filling it to give me more confidence in planking   so that's me done up to issue 18 Ive not done launch or cannons yet as i will do all those once i have got them all that will be a nice in the house job when winter comes Alan
Joined: 30/03/2010 Posts: 285 Points: 880 Location: Belton, Norfolk
Looking good so far matey  keep the pics coming.
I wish I were a glow worm, A glow worm's never glum, 'Cause how can you be grumpy? When the sun shines out ya bum!!
well its been a few weeks since Ive done anything to the Vic rib 15 caused me a few problems like most on here but also 3 others as well  though not a massive problem to sort out i do feel if we're spending £700+ then the manufacturers should get their act together    will post some more pictures once Ive sanded down Alan
Your build is coming along a treat mate, your rib 15 looks identical to mine, and I have got to build up a few other ribs in the same area too, but hey, that's modelling? Keep the pictures coming...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
I am simply astonished that something presumably mass produced and using laser technology is so inconsistent. All my ribs go exactly to the bottom of the keel apart from 15 and 16 but I can sand the keel back I little here I presume.
Or should I build the ribs up instead?
John
Hi John, best to build the ribs up mate and sand them down to the required level and not the keel... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
captainalan I'm surprised that you had so much adjustment,I only had rib 15 to adjust,and some decking.I suspect that the assembly stage is where you encountered the problems, but I see you are recovering nicely,nice neat job there,good luck with the rest. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
My rib 15 and 16 and also 25 do not reach the bottom of the keel. I will do the same and build them up.
jonny7england wrote:Hi John, best to build the ribs up mate and sand them down to the required level and not the keel... I wasn't going to but I will now, Thanks John. John
John id build the ribs up mate you can always rub down ribs to get the right contour but it will be harder to build up the keel if you take to much off Alan
 all the fairing has been done now just a quick bit of sanding to be done around the ribs just to take of the black paint i was going to spend more time on the old girl today but ive been called into work tonight so it will have to wait     nearly time for the planking  so not looking forward to putting 1st layers on her Alan
  gunports marked out and drilled  made a plug 12mm x12mm  sorry for the poor picture quality taken on a cam phone Alan
