Attaching the screen Options
Steve279021
#1 Posted : 22 December 2015 21:55:20
In the instructions it says to just use a piece of double sided to hold it on. Could a dab of glue be used instead?
Dodge charger build complete
#2 Posted : 22 December 2015 22:51:14
You'll need to use a canopy glue such as formula 560 as superglue will fog/damage the screen
Steve279021
#3 Posted : 22 December 2015 23:05:04
Would plastic glue not work or should I just stick to the instructions and use the double sided?
#4 Posted : 23 December 2015 22:34:20
Hi Steve
You can use something like this to attach the screen its what I used to do it
http://www.ebay.co.uk/sc...ue+n+glaze&_sacat=0
It looks like PVA glue to start with but dries clear.
#5 Posted : 24 December 2015 09:21:57
Great care is going to be needed, it could end up looking unsightly and no going back once you've applied it.
Steve279021
#6 Posted : 24 December 2015 10:09:53
I decided not to chance it in the end and went for the double sided route in the instructions.
This page was generated in 0.155 seconds.
