 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,488 Points: 4,376 Location: Essex
A bit more done tonight. Rear light  Roll hoop glued to chassis  Fuel filler cover panel and aerials fitted  Valves fitted to wheels  Harnesses fitted to seat and seat refitted  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
 Nicely done Steve, Its nice to see all the sub asemblys start going on and how good it looks Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cheers andy. Nearly there now. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
This mornings work. The nylon pipe running from the back of the gearbox to the front. This was really fiddly doing the pieces of tie tape (again I used cut to size insulation tape, I couldn't of imagined doing that with the kit tape!)  Gearbox attached to the engine and some more pipe connections.  And that then attached to the rest of the car and again some more pipe work and cabling.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That looks fantastic. Can't wait to get going on mine.
Cheers malc. Was hoping to get it finished for Christmas but times getting tight. Maybe I'll treat myself on Christmas day and finish it then. I'm sure the wife won't mind! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
A better pic  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
A bit more done. Gear shift cable fitted   Whole floor fitted   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Shell decals and radiator outlet duct blanking panels. I have decided to use the msm decals that I have instead of the kit ones.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Turbo ducts fitted  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Very nice build steve CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
Thank you Some detail photos before the main body goes on to cover it all up!        Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Screen is on.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
The main body is on now to cover up all my hard work! There is tape around the oil cooler duct as it came off whilst fitting the body so I glued it again after it was fitted.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 looking great but although there's loads hidden now you know its all there Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nearly there now! Main body decals finished  Rear wing stay and rear light fitted.  Nose/front wing fitted. Although I have had to order the correct marlboro decal so will need to wait for it to arrive.  Rear wing glued to the stay.  Steering wheel fitted.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Ready for it......... Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That looks fantastic. Are you tempted to display it with the body raised to show all the great details? Malc.
I did consider that but in the end I have decided to go with the body on. Photos are coming everyone!!! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Here it is, done! (With the exception of the nose marlboro decal which is on order).      Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
