15 Pages «<12131415>
steve's build Options
Steve279021
#261 Posted : 19 December 2015 23:01:11
A bit more done tonight.
Rear light
Roll hoop glued to chassis
Fuel filler cover panel and aerials fitted
Valves fitted to wheels
Harnesses fitted to seat and seat refitted
Dodge charger build complete
#262 Posted : 20 December 2015 00:10:49
BigGrin Nicely done Steve, Its nice to see all the sub asemblys start going on and how good it looksCool
Steve279021
#263 Posted : 20 December 2015 08:31:17
Cheers andy. Nearly there now.
Steve279021
#264 Posted : 20 December 2015 13:00:53
This mornings work.
The nylon pipe running from the back of the gearbox to the front. This was really fiddly doing the pieces of tie tape (again I used cut to size insulation tape, I couldn't of imagined doing that with the kit tape!)
Gearbox attached to the engine and some more pipe connections.
And that then attached to the rest of the car and again some more pipe work and cabling.
RM1
#265 Posted : 21 December 2015 05:46:44
That looks fantastic.BigGrin Can't wait to get going on mine.Cool
Steve279021
#266 Posted : 21 December 2015 09:31:16
Cheers malc. Was hoping to get it finished for Christmas but times getting tight. Maybe I'll treat myself on Christmas day and finish it then. I'm sure the wife won't mind!
Steve279021
#267 Posted : 22 December 2015 20:23:15
A better pic
Steve279021
#268 Posted : 22 December 2015 22:00:17
A bit more done.
Gear shift cable fitted
Whole floor fitted
Steve279021
#269 Posted : 22 December 2015 22:34:23
Shell decals and radiator outlet duct blanking panels. I have decided to use the msm decals that I have instead of the kit ones.
Steve279021
#270 Posted : 23 December 2015 17:24:45
Turbo ducts fitted
S2ksean
#271 Posted : 23 December 2015 17:27:39
Very nice build steve
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Steve279021
#272 Posted : 23 December 2015 17:37:28
Thank you
Some detail photos before the main body goes on to cover it all up!
Steve279021
#273 Posted : 23 December 2015 17:41:02
Screen is on.
Steve279021
#274 Posted : 23 December 2015 18:46:46
The main body is on now to cover up all my hard work! There is tape around the oil cooler duct as it came off whilst fitting the body so I glued it again after it was fitted.
#275 Posted : 23 December 2015 22:29:08
BigGrin looking great but although there's loads hidden now you know its all thereCool
Steve279021
#276 Posted : 24 December 2015 14:32:44
Nearly there now!
Main body decals finished
Rear wing stay and rear light fitted.
Nose/front wing fitted. Although I have had to order the correct marlboro decal so will need to wait for it to arrive.
Rear wing glued to the stay.
Steering wheel fitted.
Steve279021
#277 Posted : 24 December 2015 14:59:16
Ready for it.........
RM1
#278 Posted : 24 December 2015 15:14:50
That looks fantastic. BigGrin Are you tempted to display it with the body raised to show all the great details?
Malc.
Steve279021
#279 Posted : 24 December 2015 15:19:56
I did consider that but in the end I have decided to go with the body on.
Photos are coming everyone!!!
Steve279021
#280 Posted : 24 December 2015 15:23:37
Here it is, done! (With the exception of the nose marlboro decal which is on order).
