2 Pages 12>
build jig Options
johny5
#1 Posted : 01 April 2013 18:02:11
hi all im just thinking about making a build jig any one have some tips on how to build one thanks allBigGrin
#2 Posted : 01 April 2013 18:04:35
Hi Johny I hope this helpsBigGrin Kind regards Mike
johny5
#3 Posted : 01 April 2013 19:03:59
thanks Mike BigGrin
dizz16
#4 Posted : 12 April 2013 15:19:40
Thanks Mike! I just went and bought the same. Easy but effective!
ronald305
#5 Posted : 24 December 2015 01:57:47
Nice Build Jig Mike
I know where to get the angle plates for the Jig but may I ask
what kind of board that is and what size is it and once I have the
angle brackets in place do I need to screw in to the keel to hold it in place or can I just slide model in place to hold it straight thank you
Ronald
#6 Posted : 24 December 2015 09:22:39
ronald305 wrote:
Nice Build Jig Mike
Ronald
Hi Ronald, buildboards I use are either shelving boards or MDF and are at least 15mm thick, preferably 20mm. The keel is not screwed to the brackets, it simply slides into place. Hope this helps....
ronald305
#7 Posted : 24 December 2015 16:53:06
thanks Alan it did so shelving boards will be the right length
Ronald
#8 Posted : 24 December 2015 17:52:23
Hi Ronald, my build board for the Victory is 1m long, 30cm wide and 20mm thick, made from MDF.
ronald305
#9 Posted : 25 December 2015 00:43:56
OK thank you
Ronald
GilShapley
#10 Posted : 26 December 2015 13:33:20
You may find this Jig useful at a later date, particularly when cutting out the gun ports on the Victory. I found that being able to work on the hull when it was at a 45 degree angle made the job easier
Gil
Current Build:-
ronald305
#11 Posted : 26 December 2015 16:29:36
thanks Gil that is a neat jig could you give me the Dimensions for
your 45 degree support jig
Ronald
GilShapley
#12 Posted : 26 December 2015 17:08:07
Picture attached
Gil
Current Build:-
ronald305
#13 Posted : 14 January 2016 01:43:58
Hi Mike
would you know the spacing between the angle brackets or do I just measure the keel thickness once I get the first pack
Ronald
#14 Posted : 14 January 2016 10:16:01
Yes just use the keel thickness to determine the bracket gap
ronald305
#15 Posted : 15 January 2016 17:20:01
Thanks mr T
Ronald
#16 Posted : 15 January 2016 22:05:44
Hi Ronald
Have you made a start on your Victory yet?
I have had nearly a year of downtime on my hobbies for various reason and must admit i am struggling to get back into things.
My victory got as far as cutting the gunports but not the full completion of the hull planking.
It would be great to see someone making a new start to give me some encouragement to continue.
Hope your build gets off to a flying start
ronald305
#17 Posted : 09 February 2016 20:17:15
Hi Tony
I just started mine yesterday trying to make my building jig as I'm writing this, trying to find out the distance between each bracket
Ronald
#18 Posted : 09 February 2016 20:26:32
Its fairly straight forward.
Pencil in a centre line onto your baseboard.
Offer up the false keel from the victory kit to your baseboard then line up your brackets each side ensuring that none of them cover the slots for the ribs.
Hope it goes well for you BigGrin and post up some pictures of your build should you have any issues.
ronald305
#19 Posted : 10 February 2016 15:26:19
Will try when I get home
Ronald
ronald305
#20 Posted : 11 February 2016 02:32:50
Hi guys
I know making the build jig should be straight forward,
But mine is giving me a hard time I'm having
Trouble screwing in the brackets even, one
ends up a little tight and one a little loose
Can the keel sit in the brackets a little loose
I really need help here even when I use the
Keel as a guide any information or suggestion
would be greatly appreciated
Ronald
Guest (7)
2 Pages 12>
This page was generated in 3.171 seconds.
