To glue or not to glue. Options
max001
#1 Posted : 29 December 2015 05:32:06
My Lancaster had a few removable panels after a few mishaps I glued them up, except the fuel tanks and life raft in the port and starboard wings. Looking at the removable panel on the spitfire and its size put a thought in my head, down the track damaged panel can you? buy a replacement panel or do you have to buy another issue. Well the machine guns nothing to write about one in each wing, panel glued down max001.
#2 Posted : 29 December 2015 10:01:16
Spare plate material is supplied, simply cut a replacement if need be.
Both guns go into the right wing half which has the removable panel, there are no guns placed within the left wing half.
This page was generated in 0.100 seconds.
