2 Pages 12>
Planking Trough Options
Mac
#1 Posted : 18 September 2010 23:33:20
Sorry for size of pic having trouble with resizing. This is my solution for plank soaking anyway it works for me. Went to wicks got a lengh of gutting the square kind for stability, two ends bits and some sealent. Cut guttering to size in this 24inchs and attached ends and sealed with sealent. Works like a dream only needs topping up every so often with hot water. BigGrin
Pam's shipyard is closed for now no more room!
Jack Sparrow
#2 Posted : 18 September 2010 23:37:35
Nice idea!! I use an old spaghetti boiler, same principal but vertical!!BigGrin BigGrin Cool
Lonestar Spirit
#3 Posted : 18 September 2010 23:38:15
Nice idea Pam, you having a brain storm today? Flapper LOL I wonder if my neighbors will spot the section of guttering missing LOL LOL
Ship Builds on the go
#4 Posted : 18 September 2010 23:46:07
Hi All...
Another way is get 450mm of kitchen waste pipe(35mm) and a screw on blank for the bottom. use the u clips on side of bench with the pipe clamped on. fill her up when cold unscrew the bottom drain away in bucket....
Mac
#5 Posted : 18 September 2010 23:53:31
Of course it was a brain storm and it was painful! Flapper ! Everything else I pinch from youse lot! LOLLOL LOL
Jack Sparrow
#6 Posted : 19 September 2010 00:00:35
magpie1832 wrote:
Hi All...
Now you just getting technical!!!!LOL Flapper LOL LOL
Dontshootme
#7 Posted : 19 September 2010 01:23:36
LOL Snap Mac,did that on Monday myself...I went to B&Q though.
secretreeve
#8 Posted : 19 September 2010 05:26:28
or ya could just shove them under the tap for an hour? good exercise lol
#9 Posted : 19 September 2010 08:51:56
magpie1832 wrote:
Hi All...
Beats the heck out of my empty milk bottle that I've been using...LOL LOL
Jamie
#10 Posted : 19 September 2010 11:02:32
Cracking idea Pam ThumpUp I'm just gutted BlushingBigGrin that I didn't thing of something like that before. Got to be honest the only planking job I've done so far is on my HMS Bounty Jolly boat, which I just about finish (pictures to follow later today), which I didn't soak the planks just bent them using and electric bender and kept fingers crossed Glare LOL
Anyway, if you wanted to free up the work space taken by your guttering then you buy a couple of brackets to go with it and stick up on the wall Cool
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
Mac
#11 Posted : 19 September 2010 11:15:46
Good idea Jamie, also it could be made smaller to save space as this one is 24 ins. Was'nt sure when I put it together how long Vics planks would be. BigGrin
#12 Posted : 19 September 2010 11:41:25
mine isa high tec solution, I use a mop bucket and stick one end of the plank in that.only bending the one end.but a brilliant idea mac,go to the lion's den with one.
#13 Posted : 20 September 2010 00:20:18
I just use a shallow baking tray from the kitchen. It doesn't even need to be non-stick Flapper
PDyner
#14 Posted : 20 September 2010 13:59:34
Hi
I think I've got the most sophisticated and technically advanced, very specialized device to soak the planks. Here it is:
As you can see it is plastic bag, in which the planks arrived, very precisely cut 2cm shorter then planks, and pinned with high precision to my work table. Then you have fill it with water exactly on room temperature, and that is. This device hold about 8-10 planks at once.
Prem Dyner
Quintin
#15 Posted : 20 September 2010 14:09:48
When I was planking my Endeavour, I broke quite a few, so ended up sticking some in the dish washer and running them through a cycle. When they came out, they were nice and pliable. Un-orthodox, but worked
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
MadDogMcQ
#16 Posted : 20 September 2010 15:59:57
And the winner is....... P Dyner!
Quentin Tarantino - Hallowed Be Thy Name!
riff-raff
#17 Posted : 20 September 2010 16:08:49
Pint glass works perfectly - and I can keep my cider in it while I'm not bending planks - multi-purposeFlapper Flapper
Built:
ArtfulBodger
#18 Posted : 27 September 2010 23:26:02
This is a great solution but I tried it originally with hot water and the ends severely warped. Perhaps the water was way too hot.
Now on the Mk. 2 trough with cold water ok.
ArtfulBodger
Previous Build:
HMS. Bounty
piot007
#19 Posted : 28 September 2010 07:24:34
PDyner wrote:
Hi
LOL I did the sameLOL
willie
#20 Posted : 28 September 2010 10:53:03
i use the bath room sink the shape of the bowl lets me start the bend whilst the plank is socking buy pussing the plank on the carved part of the bowl finish with plank benders
2 Pages 12>
