Gluing the planks Options
z8000783
#1 Posted : 28 September 2010 08:33:29
Groups: Unapproved
Having read the magazine about 15 times it seems to imply that when glueing the planking that only the points where it touches the ribs needs to be glued.
I have not see it mentioned anywhere that you should glue the edges of the planks together i.e. glue the whole length of the plank.
What is the feeling amongst the members here about this.
John
ROUGHJUSTICE
#2 Posted : 28 September 2010 08:46:46
Rank: Beginner Level 3
It is a must to glue the edges of the planks ,particulaly when you go to cut out the gun ports ,it will all start to come apart around the gun ports, planks springing out etc.
hope this helpsBigGrin
alantait
#3 Posted : 28 September 2010 08:51:19
i agree, you must glue the edges of each plank as you will end up with sprung planking at every gunport, this will not allow the planking to flow around the hull and will be almost impossible to rectify without major clamping.
current builds
z8000783
#4 Posted : 28 September 2010 08:54:58
Groups: Unapproved
Thanks guys, yes I forgot about the gun ports, obvious really when you think about it.
It wasn't clear from the instructions though, well at least to me anyway.
John
Quintin
#5 Posted : 28 September 2010 08:59:34
You were right though, in the teaser video, it clearly shows the guy only glueing the ribs. You might get away with that if the model is double planked, but not on single planking, with gun ports. Interestingly, my AL Endeavour was double planked, but the gun ports were only dummys with no need to cut any deeper than the veneer. Bummer, now I look back, that I didn't go all the way and modify it, to include the extra guns. Glare
Part time modeller, full time biker
Built: Pinta
Belle Poule (plastic)
Endeavour
Scratch build of Pirate ship "Neptune" (Based on cutter "HMS Aldebaran"
Current builds: Victory
#6 Posted : 28 September 2010 09:23:47
John
Step 14 of issue 21 says to apply glue to the frames and to the lower edge of the planks, all of the hull planks should be glued to both frame and along their length to each other.
z8000783
#7 Posted : 28 September 2010 09:26:27
Groups: Unapproved
You're right, I missed that. I guess I need to read it all a few more times.
I also noticed it's in the build diary, sorry about that.
Thanks.
John
thomasmoult
#8 Posted : 28 September 2010 19:54:19
It will also make the ship a hell of a lot stronger!
Tom
piot007
#9 Posted : 29 September 2010 10:02:52
Mornin all. Can anyone tell me if this is a bad idea.
After shaping and bending the planks to the desired effect. Is it a bad idea to shave off up to 45degrees on the backside of the plank. top and bottom to make the join seamless. So instead of of rectangular shaped plank( looking down the length) its now a parallelogram. Laying on top of each other would make it 'lock' into position. Maybe buying new planks that were 1mm wider to compensate for the loss of material on the floor. Or is this just far too much work to bother with.
piot007 attached the following image(s):
bripfc
#10 Posted : 29 September 2010 11:39:37
sounds a good idea, but prehaps Tomick could shed some light on this
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
#11 Posted : 29 September 2010 12:16:04
piot,have a look at my victory build,and have a look at my joints,is that what you mean?all the strakes on my build have 45degree joins,when these are sanded down,they become almost invisible.
#12 Posted : 29 September 2010 12:30:34
Lonestar Spirit
#13 Posted : 29 September 2010 12:32:56
Excellent example and illustration Chris!!!! nicely done! BigGrin
Ship Builds on the go
z8000783
#14 Posted : 29 September 2010 13:01:11
Groups: Unapproved
It does seem like over-engineering in the areas where the planks lay flat anyway.
John
turboman
#15 Posted : 29 September 2010 21:10:49
hi all do we have to shape all the planks
cheers turboman
Zeptrader
#16 Posted : 29 September 2010 21:49:14
No, not all of them, and not the entire length on certain planks, just offer them up to the part of the hull that your planking and see what needs a little sanding.
The above shaping is vital to avoid any gaps between the length of the planks.
Don't just bung the plank on, always dry fit first (holding the plank up against the hull) Take your time and it will be perfect.
Hope that helps.
turboman
#17 Posted : 30 September 2010 00:40:13
many thanks zeptrader
cheers turboman
This page was generated in 0.170 seconds.
