8 Pages <12345>»
Rockwell b1b bomber Options
mark 2
#41 Posted : 10 January 2016 09:31:51
Sorry I forgot to say that in photo 6 I added the Eduard photo etch and will be detailing more at a later date.
Best regards all.
#42 Posted : 10 January 2016 09:49:01
Ooooh I missed you starting this, looking great so far. Pulling up a chair and grabbing my popcorn BigGrin
#43 Posted : 10 January 2016 10:12:10
BigGrin Nice start on the beastCool
mark 2
#44 Posted : 10 January 2016 11:43:11
Hi Dave BigGrin .
I would not pull up a chair yet as you may have a few grey hairs by the time I finish LOL LOL .
Thanks for looking.
Best regards.
mark 2
#45 Posted : 10 January 2016 11:44:35
Hi Andy BigGrin .
Thanks for looking in.
Best regards.
#46 Posted : 10 January 2016 13:14:24
Up and running I see Mark, great start....Cool Cool .. Will be watching as this has the makings of being a great build to follow.....Cool Cool
mark 2
#47 Posted : 11 January 2016 05:55:39
Hi Alan BigGrin .
Thanks for your kind words and for looking in on me.
I will try to make for a great build.
Best regards.
mark 2
#48 Posted : 11 January 2016 06:11:15
Hi All BigGrin .
Just a quick update.
I decided to make up the bombs yesterday ( all 16 of them ).
The fit was not great as the seams over hung in places which were down the side of the bomb and at the back where the front of the tail fin is.
They will take a lot of tidying up. Still will stop me getting Bored .
Thanks for looking and any questions or advice greatly received.
Best regards all.
mark 2 attached the following image(s):
mark 2
#49 Posted : 17 January 2016 11:38:38
Hi Everyone BigGrin .
I am a bit Cursing Angry as there should be 4 of these parts and I have only 3 so I thought rather than send of for the part I would like to have a go at making it in resin as I have never done anything like this before.
Can someone advise me of the best way to go about this i.e. making a mold
and what resin to use.
Any help would be gratefully received.
I enclose a couple of photos of the part in question.
Thanks and best regards to all.
#50 Posted : 17 January 2016 12:03:08
Hi Mark, sorry to hear you have a part missing...Crying Crying .. If you want to get into the world of casting your own parts then you may find some useful info in the 'Tools and Consumables' section of the forum...
#51 Posted : 17 January 2016 12:18:27
BigGrin Hi Mark
Sorry about the missing part but it can be fixed with a moulding kit, the last kit I bought was from this suplyer and the small one should suit your needs unless you intend to do more then a larger set would be better.
http://www.mbfg.co.uk/ca...ng-resin-kit-small.html
To make the mould make up a box with wood or thick card with a base that is at least a third larger than the part to be made this includes length width and depth. once you have made the box place the part inside it and then mix up the silicon rubber and pour over the part in the mould filling it up. Leave the mould to cure then you can either just remove the base and leave the sides on or remove all the box completely. After that remove the original part from your mould and then mix up some resin as per the instructions pour and allow to set.
I did a tutorial a while back using a different kit and here is the link,
http://forum.model-space...aspx?g=posts&t=5628
Hope this helps
mark 2
#52 Posted : 17 January 2016 19:20:57
Hi Alan BigGrin .
Thank you for looking in and your help which is always appreciated.
Best regards.
mark 2
#53 Posted : 17 January 2016 19:30:10
BigGrin Hi Mark
Hope this helps
Hi Andy BigGrin .
Thanks for looking in and the link and advice which will help very much Cool .
Many thanks and best regards.
mark 2
#54 Posted : 24 January 2016 21:46:23
Hi All BigGrin .
I have now sent of for a resin casting kit and now eagerly await it.
I have a small update.
I have managed to do the ladder that gains entry for the pilots and here is a couple of photos of the said item.
The ladder and etch went together quite easily and I am pleased with the outcome.
Thanks again for looking and any thoughts or questions pleas don't hesitate to ask.
Best regards.
#55 Posted : 24 January 2016 21:51:08
Nice work Mark on what looks like some quite fiddly etch, very neat and tidy, and a great improvement on the kit parts!!
Well done!! Cool ThumpUp
#56 Posted : 24 January 2016 21:59:13
Well done on the ladder, looks so much better!BigGrin
mark 2
#57 Posted : 25 January 2016 07:11:22
Hi Kev BigGrin .
Thanks for looking in and your kind words.
I agree with you that it is far better than the kit parts.
Best regards.
mark 2
#58 Posted : 25 January 2016 07:13:23
Hi Nem BigGrin .
Thanks for looking in and your great comments.
Best regards.
mark 2
#59 Posted : 27 January 2016 22:56:12
My casting kit came yesterday BigGrin .
So I made up a little box for the silicon rubber and mixed it up and poured it into the box with the part in the bottom of the box.
Once it had cured I noticed the part had been pushed to the top of the box which is normal procedure.
I then took the box apart to take out the rubber and removed the part from the rubber and then mixed up the resin and poured it into the rubber mold and after around a couple of hours I pressed out the resin part and was very pleased with the result as can be seen in the last photo.
Not bad for my first attempt.
I would like to send Andy a massive thank you for his help with this.
Best regards all.
#60 Posted : 28 January 2016 11:33:02
That is an excellent first attempt Mark, turned out really well?!! Cool Cool ThumpUp
No holding you back now that you have the knowledge as all sorts of upgrades/enhancements can be moulded from a single scratchbuilt master?!
Well done!! Cool Cool ThumpUp
8 Pages <12345>»
This page was generated in 0.383 seconds.
