Admiralty Paints Help Use With Airbrush! Options
RussG
#1 Posted : 29 September 2010 17:49:52
Good Evening My Fellow Shipmates. BigGrin
Can anybody tell me if you can use the Admiralty Paint set with an Airbrush? If so what is the best solution to use with it to stop it drying out to fast on the needle, as I have found out in the past using water based paint. Crying
Many Thanks In Advance (MTIA) BigGrin
Happy Building, Russ
#2 Posted : 29 September 2010 18:07:23
Hi ,
Mixing it to consistency of milk (with water), also add a couple of drops of fairy up liquid not too much and have your air pressure low. If you have it high it will splatter and dry out too quick.
Hope that helps :)
Chris..BigGrin
PDyner
#3 Posted : 29 September 2010 18:07:40
I think you can use retarder (hope I spelled it well). they are usually used for acryllic paints. So because those paints are waterbased as Admirality paints it sholud work
Prem Dyner
This page was generated in 0.132 seconds.
