Gun port linings issue 47 Options
SimonC
#1 Posted : 11 January 2016 19:50:25
Rank: Amateur Level 1
Just need some clarification on this. I have just added basswood strips to inside of the bulwarks on deck 3 and painted them red. It says in the instructions to smooth the wood before painting - which I did. My question is: Should the gun port linings be flush with the inside of the bulwarks? Mine protrude a little. It is not a problem sanding them flush with the added basswood. In any event when the 1x3x300 basswood strip is added (in issue 48) a slight protrusion will hardly be noticed. I know this is all cosmetic and not that important but would value anyone's input on this.
#2 Posted : 11 January 2016 20:15:36
Hi Simon, after I lined the bulwarks I again sanded everything smooth ensuring the gunport lining were flush. It just tidied everything up nicely.
Hope this helps.
SimonC
#3 Posted : 12 January 2016 20:52:36
Thanks Alan - I will tidy this up. Since finishing the hull it seems to be progressing much faster - lots of fiddly jobs but no major repetitive work. SOS is looking good - I will post some pictures soon.
This page was generated in 0.647 seconds.
