Parts in Issue 15 Options
Darrin45
#1 Posted : 30 September 2010 13:37:02
Rank: Newbie
Groups: Registered, registriert
Hello new to ForumBigGrin in Issue 15 there were some parts numbered 33 & 34 2 of each where do these go?,as I couldnt see on instructions.If anyones got any pics they they can post that would be great.
bripfc
#2 Posted : 30 September 2010 13:45:06
if you go to tomick on the offiacal build site offical build you be able to see but it should show you issue 16
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
axle396
#3 Posted : 30 September 2010 13:46:10
Hi Darrin,
Confusing as it may seem, the instructions with issue 18 show where these parts are placed. The two parts 33 are glued to the outermost gallery supports and the twoparts 34 are glued to part 31. flush with gallery supports. Hope this helps.
Jimmy L.
Revell USS Kearsarge
Titanic Lifeboat
This page was generated in 0.086 seconds.
