My gallary is to high!!! Options
Tarbrush
#1 Posted : 30 September 2010 21:49:19
Blushing Hi shipmates has anyone else had this problem due to pt31 not going home!
I discovered this when planking the bottom of the gallery as it required to many planks to get down to the level of the lower gun deck.Mad
I have now successfully solved the problem with the help of a razor saw Crying and some dreaded balsa. There should be no ill effects.Mellow
Let me know if any of you would like a description of this rather radical solution.
Full marks to the instructions by the way, as they did warn to check pt31 was seated properly. MORAL: Read the b----y instructions very carefully and double check.Blushing
pall mall
#2 Posted : 30 September 2010 22:05:48
Rank: Beginner Level 3
hi tarbrush, glad to hear you sorted things.i had the same trouble with several ribs being to tight had to sand and make fit ,still i suppose things will get even tougher when we reach the rigging stage.
#3 Posted : 30 September 2010 23:51:36
that's what i like a good dose of optimism LOL LOL LOL
This page was generated in 0.179 seconds.
