Cannon’s Options
Carlos The Jackal
#1 Posted : 24 January 2016 14:43:04
Rank: Beginner Level 1
I’ve now started with the cannon’s. I’ve only managed the woodwork. I’ll be keeping them in the natural wood look.
#2 Posted : 24 January 2016 16:50:15
Carlos
Moving along nicely with this one.
Page
#3 Posted : 25 January 2016 01:50:20
Rank: Amateur Level 1
Page
#4 Posted : 25 January 2016 01:57:41
Cool I like what your doing Carlos. Seems like it is better to build one part of the canons rather than doing each one at a time. Do you use a any type of jig?
. what was your method for cutting out the Gun Ports?
Page
Carlos The Jackal
#5 Posted : 25 January 2016 10:23:10
Page
Hi Page
I marked all the Gun Ports and then I drilled the four corners and the centre with a 2 millimetre drill. Then I used my Dremel to cut out the ports.
Hope this will help you.
This page was generated in 0.110 seconds.
