Problem with step 4 stage 109 Options
m0325
#1 Posted : 27 January 2016 21:46:23
I need some help on stage 109 step 4. From the attached photo you can see where I laced the 3X3 on the edge. When I do this, the engine cover does not sit properly over the engine compartment. It would seem that i put that short stick 3X3 in the wrong place but it looks like it should be there according to the instruction picture in step 4. Can you help
Warthog
#2 Posted : 27 January 2016 22:31:39
Hi
You have glued the piece of 3x3 on top of the frame where it supposed to be on the side level with the top of the frame.
I have also removed your other posts regarding your problem as I see no need to ask the same question 3 times BigGrin
Spencer
This page was generated in 0.226 seconds.
