Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Thanks for all the feedback on the painting guys,quite pleased with it myself for a first go, probably will have a go at the lower hull next.Just a couple of questions for those in the know .1 why do vallejo air and model paint versions of hull red look completely different.And 2 does anyone know a good way to weather the wooden deck veneer, I'm a little worried that stain or a wash might affect the sticky backing? nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
 Hi Nightwisher The colours are different as different navy's, country's used different shades of anti fowling red as a note most merchant marines from each country also used the shade available in there country's. The red red colour is closer to British Navy anti fowling red where as the more purple one is closer to the Imperial Japanese Navy anti fowling red. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for clearing that up Andy,shame the one I need is not the air paint,will just have to thin the other one. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
coming back to you on the deck question. I would use some of the scrap to test, but I think if you were to seal the deck with matt varnish first that would protect the deck from any soaking from a wash. however I would still be very carful and only pin wash. unfortunately the areas you want to show shadow etc will be where the veneer meets the plastic and will allow the wash to get under the adhesive backing. test it on some scrap, but I would be very carful personally. hope that helps? Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Rather than a wash perhaps you could use pigments instead or alternatively I've seen someone very lightly mist over the wooden deck with an airbrush to great effect, they used Tamiya XF20 medium grey thinned about 90%
Thanks for your thoughts Jase and Davetwin.I have just brought some tamiya weathering master kits (the ones that look like makeup )will test them out later (on the model not my face) Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Hi Nightwisher. Great start to your build. love the camo paint job. look forward to seeing your progress Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks for looking in Ian,time for a small update. Didn't get much done this weekend (stupid valentines day).I had a go at weathering the wooden deck with a tamiya weather master kit using mud colour, quite pleased with the result. I also tried to rust the steel plates ,not sure about how this turned out , only the rear deck is fixed down so far. nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
 Well done m8 looking good Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Wow  that looks brilliant. You have to give credit to Matchbox for putting out a kit all thise years back that can still be turned into an outstanding model with some skillful building and a great paint job. You are doing a fantastic job on this one - its a real treat to see Happy Modelling
Now this is turning out to be a build with real character. Fab job you're doing, look forward to seeing more on this one..... Very well done..... Regards Alan
I really like how the deck turned out, quite authentic looking
Great progress (mine is still on the shelf of doom, can't remember why) word of warning though I looked at it a couple of weeks ago and the wooden deck was all curled up and ha almost rolled into a tube I unrolled it and put some heavy things on it, it might pay you to keep an eye on yours like the weathering on your deck looks amazing. Ken's the name modeling's the game.
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi folks, haven't done a lot in the last few weeks (can't believe we're in the third month already, starting to doubt it will get finished in time).I have painted the bottom of the hull, fitted the support beams on the rear deck and assembled the wheel house. I added some framing around the windows with plastic strip. Ken you were spot on with the deck sheet curling up, I have noticed mine is starting to lift on the edges and so have glued them back down, thanks for the warning. nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Whats that saying about "time and tide wait for no man?" And these days its so true. I always thought it just me noticing how quickly time passes these days but it seems i am not alone in that. Like you i cannot beleve how the year is flying by again. Ship is looking very good indeed. Happy Modelling
Hi guys,sorry it's been so long, have been really busy at work leaving hardly anytime for modelling. I have been doing bits and pieces here and there, have finally managed to get all the decks glued down without too much trouble. I have done some weathering using vallejo rust and black washes,hope I haven't gone overboard ( sorry about the pun ) . nightwisher attached the following image(s): Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Now this is coming together very nicely, the weathering effect looks about spot on..... Look forward to your next update.
Superb weathering! Nice build, looking forward to seeing more!
