Light blocking the hull Options
rj1265
#1 Posted : 29 January 2016 23:01:39
Rank: Amateur Level 1
If adding extra interior lighting / maybe landing lights will the inside of the hull need to have any extra coatings to stop light bleed through ?
On the WorkBench : DeAg Millennium Falcon , Deag R2-D2
To Build : various 1/72 , 1/32 WW II Military Planes
#2 Posted : 29 January 2016 23:29:46
BigGrin Hi RJ
You could build individual light boxes from plasticard if you have room but most people generaly apply heavy duty aluminium foil to the insides of the model surfaces to prevent light bleed.
BradM73
#3 Posted : 30 January 2016 02:50:14
If you're going to completely paint the exterior of your Falcon, that should provide sufficient light blocking. Some people are also putting extra layers of paint on the inside of their Falcon's as well for the extra touch.
greyhawk
#4 Posted : 30 January 2016 02:54:51
#5 Posted : 30 January 2016 11:16:29
I would wait and see until after you have paineted it, you can then go back and paint any insde areas or use aluminium ducting tape.
This page was generated in 0.255 seconds.
