new build Options
bripfc
#1 Posted : 04 October 2010 13:42:02
well chaps i seem to be getting on ok with the victory few tething problems with the planking but thats about all i was thinking about subscribing to the cutty sark build but am i taking on to much being new to this type of model building? views welcome/please adviseConfused Confused
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
PLAY UP POMPEY!!!no wise cracks
RussG
#2 Posted : 04 October 2010 14:07:17
Hi Brian, The planking will come with time and practice, the best advice I can give is take your time, measure twice cut once!!BigGrin Im also thinking of getting the Cutty Sark, she looks like a good build, the problem I have is SPACE! they get big as the build progresses! so it might be a case of get it and pack it away untill Victory is finshed, LOL
Happy Building, Russ
bripfc
#3 Posted : 04 October 2010 14:12:17
cheer for the adive i too have limited space so i have had to pack some of my other collections away but i think it will be woth it,its not so much the cutting of the planks but i dont think i got the sanding of the chamfer right as i ve got small gaps now but a bit of filler will work as im painting it.
Brian
Current Builds
HMS Victory
HMB Endeavour
HMS Hood
secretreeve
#4 Posted : 04 October 2010 15:24:50
cani recomend the endeavour longboat?
im going it at the moment, you can see my build log by clicking endeavour longboat in my signature, it may be a small boat but does give you nice practice with planking. i've found it so far, thouroughly enjoyable. i took the 3 month script and part it looks like part 3 is going to be a VERY busy issue with masts rigging finishing the hull and all sorts, definatly a fun build
RussG
#5 Posted : 04 October 2010 15:27:41
Hi Brian, This might help you, Its all about Planking!!!
http://www.anr-disco-kar...oks/plankingproject.pdf
captainalan
#6 Posted : 04 October 2010 17:59:31
Brian
put some pva clue in the cracks and a sprinkle of sawdust from the planking will sort out small gaps
This page was generated in 0.135 seconds.
