Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Got issue 57 today The main switch goes on the side of the hull Test button A on the circuit board is to test the ramp and light Test button B on the circuit board is to test lights that have not been connected yet. The landing gear switch I'm not to sure but it could be a safety switch so you don't beggar the landing gear. External power socket has a rubber cover so hopefully it will blend into the damage on the hull.    Looking at the wiring diagram schematic the main switch goes here.  Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Joined: 08/03/2015 Posts: 154 Points: 435 Location: New Jersey
spudtrooper37 wrote:Got issue 57 today The main switch goes on the side of the hull Test button A on the circuit board is to teat the ramp and light Test button B on the circuit board is to test lights that have not been connected yet. The landing gear switch I'm not to sure but it could be a safety switch so you don't beggar the landing gear. External power socket has a rubber cover so hopefully it will blend into the damage on the hull.    Looking at the wiring diagram schematic the main switch goes here.  Someone on Facebook said that the green wire on the switch wasnt long enough to reach where it had to go. It looks like yours is fine. My current builds: The Millennium Falcon, Suzuki GSX 1300R Hayabusa, Ford Mustang Shelby
Seen that too, believe they mistook the main switch for the landing gear switch Darren
Hi everyone, not been on for a while. Just plodding along with the build, up to issue 63 and something I have noticed is that I believe the whole engine part will be one piece and removable (possibly to gain access to circuit board) The original had 3 allen bolts down each side and the frame on the ours has 3 threaded holes but no other holes in rest of the frame.    Darren
Joined: 25/05/2015 Posts: 66 Points: 204 Location: Minneapolis
Nice work, Darren. You're really staying ahead with this one; it's great to see what the next couple of months have in store. Have you screwed all the upper hull plates to the frame? Looks like you've got all the plant-on details planted on too. Are you concerned about future stages requiring something unforeseen? Anyway, keep posting!
A Thumbs wrote:Nice work, Darren. You're really staying ahead with this one; it's great to see what the next couple of months have in store. Have you screwed all the upper hull plates to the frame? Looks like you've got all the plant-on details planted on too. Are you concerned about future stages requiring something unforeseen? Anyway, keep posting! Thank you, plating has only got a few screws holding them. The greeblies are glued but will not cause a problem if I have to remove plating. Darren
Hi everyone, been a while since I posted anything. I'm upto issue 69 and now I starting to think where am I going to display her, she is getting big! Everyone on here is doing a fantastic job.     Darren
If anyone has these  then BB8 will watch Star Wars with you and interact with the film. I have watched it twice with him and is so cool. Darren
Looking Good Darren, really shows how big this beauty is. I havn't put any of the pipework in yet myself and you are several more issues ahead of me anyway. I don't have a BB8 to interact with the film, but sounds like a lot of fun, just have a wife that talks through it, Not fun!!! Regards Markwarren (Mark) Admin
Wow - and there it is! With the engine panels on, it feels more completely like the Falcon than at any other point. Quite exciting. Thanks for posting the latest stages.
Hi Darren. Really nice build. Regards Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Does this mean we'll have 6 exposed Allen screws on the final product's aft section?
Joined: 30/04/2015 Posts: 263 Points: 795 Location: Los Angeles
LeviathanPrime wrote:Does this mean we'll have 6 exposed Allen screws on the final product's aft section? At this point, that's kinda what it sounds like to me. Unless there's some greeblies to cover them up that we get at a later point. I'm assuming this is also for easy access to the interior circuit board and such.
colson wrote:LeviathanPrime wrote:Does this mean we'll have 6 exposed Allen screws on the final product's aft section? At this point, that's kinda what it sounds like to me. Unless there's some greeblies to cover them up that we get at a later point. I'm assuming this is also for easy access to the interior circuit board and such. The allen bolts are there to replicate the original model and also to give access to to electronics. Darren
spudtrooper37 wrote:colson wrote:LeviathanPrime wrote:Does this mean we'll have 6 exposed Allen screws on the final product's aft section? At this point, that's kinda what it sounds like to me. Unless there's some greeblies to cover them up that we get at a later point. I'm assuming this is also for easy access to the interior circuit board and such. The allen bolts are there to replicate the original model and also to give access to to electronics. Yes, they are definitely on the filming miniature.
They are. I don't expect to have any greeblies to cover them either. Ours just seem to be further in from the edges and larger. It's not bad. Much more drastic departures from the filming miniature are present so this is hardly a point to complain over.
Another mile stone completed, apart from the engine area all the top plating is on. Issue 72 you get the antenna and mandible frame parts :-D   Darren
Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
Great build Darren, having just completed my lower hull frame I am also trying to figure out where to display this beast. Here is a picture of an idea I am thinking about using. Thinking on having the wall mount fixed to the base and having the Falcon looking like it is taking off.  Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
spudtrooper37 wrote:Another mile stone completed, apart from the engine area all the top plating is on. Issue 72 you get the antenna and mandible frame parts :-D   Nice I am up to issue 68. Do you know what issue shows you where to put on the top piping pieces from the previous issues? Are yours temporary or glued on? My current builds: The Millennium Falcon, Suzuki GSX 1300R Hayabusa, Ford Mustang Shelby
Now it's really starting to look the business!! Great job
