7 Pages «<4567>
Building a JIG Options
ronald305
#101 Posted : 08 February 2016 17:44:45
Hi Russ
I have the board and the 2" angle plates 6 packs 2 in each pack
can I use the 6 or do I need one more pack
Ronald
#102 Posted : 08 February 2016 18:23:46
6 angle plates per side should be enough.
Just make sure you do not put them in the way of where the ribs will slide into the keel.
ronald305
#103 Posted : 08 February 2016 18:56:48
ok thanks I will
also I found out that the board is a few inches wider and 31" is that ok while I'm here would you know the space to allow for the keel
Ronald
ronald305
#104 Posted : 09 February 2016 20:55:33
hello fellows
does the keel have to fit tight between the brackets or can it have some play in it because my first bracket is a tiny bit loose
Ronald
#105 Posted : 09 February 2016 22:37:08
The brackets need to be a snug fit, otherwise the keel won't be held firm and risks the keel not being held perfectly upright at 90 degrees to the base.
ronald305
#106 Posted : 11 February 2016 02:51:00
thanks' Mr T
but if it's a snug fit wouldn't it mar the keel, when you say snug is that tight snug or able to slide in and out smoothly
Ronald
z8000783
#107 Posted : 11 February 2016 07:37:54
Groups: Unapproved
You need to be able to push the ship in with light pressure. When you start planking it is possible that the various tensions will pull her in all directions so it has to be tight.
It can be a pain when you line everything up drill the holes, screw in and it lose but if it's not too bad try packing it with thin cardboard until the fir is snug, as Tom says.
Remember also that this is the false keel and you will be planking up to it and then fitting the main keel later so any maring won't be a problem.
greyhawk
#108 Posted : 11 February 2016 21:50:31
Yeah, that's what I did. I packed any slightly loose brackets with thin strips left over from building the launch
ronald305
#109 Posted : 11 February 2016 23:05:22
thanks John
by any chance did you or anyone who built the L shape bracket version
traced the holes in the bracket and center punched & predrilled for the screws thank you
Ronald
greyhawk
#110 Posted : 12 February 2016 00:12:15
ronald305 wrote:
thanks John
Ronald
I did, I built my jig out of block board, which is unwarpable but also needs to be drilled to get anything into it.
ronald305
#111 Posted : 13 February 2016 02:43:54
Hi guys
anyone that built the building jig with the L shape brackets does the part of the bracket that holds the keel suppose to sit on the center line or keel does, I can get one bracket in place on one end and by using a
piece of wood that the keel came from but having trouble with mounting the bracket on the opposite end with out being either to tight or a loose
Ronald
#112 Posted : 13 February 2016 09:09:57
As mentioned before the keel sits on the centre line so you can see it is straight and the L shaped brackets are placed up against the keel to hold it there to stop any warping during the build. The keel should be a snug sliding fit
ronald305
#113 Posted : 13 February 2016 15:55:08
thanks RGD but I got all that for some reason I'm just having trouble with mounting the bracket on the opposite end it either ends up tight or loose when, you guys made yours did you'll circled the mark in the bracket holes then center punched them, because that is what I was doing but I think the
bracket moved while trying to mark it or my circle mark was off a fraction
Ronald
#114 Posted : 13 February 2016 16:36:18
Hi Ronald,BigGrin
If you are using countersunk screws , then the bracket will only sit in one position, determined by exactly where you drill the hole.
Try using a dome headed screw that is slightly smaller than the hole in the bracket, then with a small washer underneath the head you will have a small amount of adjustment of the bracket.
Hope this helps.
#115 Posted : 13 February 2016 16:58:00
You could also have fixed brackets along one side of the keel and slotted brackets on the other side, these could then be adjusted for any keel thickness and tightened using wing-nutsBigGrin
ronald305
#116 Posted : 13 February 2016 19:21:10
that could work thanks Steve I'm not giving up just because I'm having trouble with a simple build jig
Ronald
ronald305
#117 Posted : 13 February 2016 19:22:58
thank you to Derek
Ronald
#118 Posted : 14 February 2016 00:35:04
BigGrin Hi Ronald
Just a thought and there out of stock right now [they get restocked pretty quick usually] but this may be the way to go for a dry dock that will help you with your build.
http://www.hobbyzone.pl/...onal-building-slip.html
ronald305
#119 Posted : 14 February 2016 17:29:31
WHOOA OK thanks Andy
I just took a look at it that part with the marking it must be able to
come apart I wonder if can put a hold on one so I can purchase
Ronald
ronald305
#120 Posted : 14 February 2016 17:52:36
Hey Andy this build jig from hobby zone looks like it was design for this type of kit, anyway I have wrote to them a few minutes ago will be waiting for a reply
Ronald
7 Pages «<4567>
This page was generated in 0.177 seconds.
